4.6 from a lincoln mark viii in a foxbody swap?
Old November 20th, 2008, 04:26 PM   #1
rusty2407's Avatar
1991 Ford Mustang LX
rusty2407 is on a distinguished road
My friend offered me a 4.6 out of a 1993 lincoln mark viii for a couple hundred bucks. Id like to put it in my 91 5.0 but im not sure what all i would need, obviously a new manual trans from a newer mustang, but as far as computers go what would control this motor out of a car that only came in auto? help please before i buy it.
BBK CAI and Shorty Headers, Cobra Upper/Lower Intake, Walbro 110, 24# Injectors, larger throttle body, maf, Drilled and slotted front rotors, King Cobra clutch, Cobra wheels w/ sumitomo tires, flowmasters
Old November 20th, 2008, 04:29 PM   #2
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
why not put the automatic in it?
the wireing is gonna be the fun part
<font size=4><b>MILITARY CREW
Old November 20th, 2008, 04:34 PM   #3
rusty2407's Avatar
because i wanna build a road course car, and automatics bore me haha, i still always shut off my daily in drive as soon as i pull the ebrake thinking its a manual.
Old November 20th, 2008, 10:42 PM   #4
1986 LX
none yet
jtyson8602 is on a distinguished road
t45s are usually pretty cheap used. and sean is right, wiring will be the hard part. But the 4.6 swap is common, it has been done quite a few times so there should be plenty of literature around online that would help you out.maybe like this
Engine Swap - Ford 4.6 Dohc Into Fox-Body - Hot Rod Magazine
Old November 20th, 2008, 11:27 PM   #5
Racinjason81 is on a distinguished road
you should also get the entire wiring harness and pcm and a Lincoln EVTM (wiring book) for that year mark8 .you can go to your local lincoln dealer and order a evtm. you will need a 4.6 k member like a QA1 for example. an electric fan preferably a mark8 fan from the same year car.you will also need a cobra 8 bolt flywheel.A t45 ,t3650,t56 or TR6060 trans all came stock in mustangs and fit 4.6s. you could convert it over to a carb if you really wanted.Fast xfi is one of the stand alone computers that would run you engine with a little modification.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Threads Similar to: 4.6 from a lincoln mark viii in a foxbody swap?
4.6 from a lincoln mark viii in a foxbody sway? rusty2407 Modular Mustangs 18 May 5th, 2009 01:30 PM
Lincoln Mark VIII to 04 GT swap Straits15204 99-04 7 June 17th, 2008 06:04 AM
Lincoln Mark VIII 4.6 MikeyS281 99-04 7 June 13th, 2008 12:20 AM
