LinkBack (1) | Thread Tools |
#1
1990 mustang GT
what size throttle body ?
my 90" GT is bone stock. i'm buying parts for my build now. what size TB is recommended for making 260 to 300hp ? (i am using a cobra intake.) thanks
Skirt Chasing Phallus Phondler
Kit Car/Ducati/Explorer
Nike Fast
A cobra intake is 70mm, so you realy dont need to go bigger than that if you never plan on changing to a bigger intake.
QUOTE OF THE DAY (5/25/12): “Don’t play what’s there, play what’s not there.” ‐ Miles Davis |
Fine with a 65 mm
PeteAndersonRacing.com |
70mm
I recomend 65 or 70 runs beter if TB smaller than MAF
Nike Fast
So get the cobra intake, 70mm TB, and C&Ls 76mm mass air and elbow combo...
ya C&L kicks ass I had that combo and ran great
65 for mild setup.
Bart 93 Black on Black GT Kenne Bell S/C ![]() GIVE 'ER! |
1990 mustang GT
thanks guys ! what size MAF comes on the newer years ? i don't need to change injectors do i ?
#10 | |
1989 GT
KB 2.1L Flowzilla
If you want close to 300 rear wheel hp then those stock injectors arent enough, step up to 24s with calibrated MAF. Heres a good chart from Darrells archives, those are flywheel hp.
dont get any bigger than a 65 i guarantee you make more rwhp with a 65 than a 70. guarantee
#12 | |
95 opalfrost gt
Thats a bold statement, is this based off of hard data, personal experience or myth?
#13 | |
2002 Gt
Not Slow
i would go either 65-70mm depending on supporting mods
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
No need to go above 65 for that power level.
I've got a 65mm Professional products throttle body that was ran for about 2000 miles. Still got box and all. $75 shipped. Pm if youir interested. |
If your running a 302 with mild boltons(n/a) you want need more than 65mm If you plan for more in the future get a 70mm
#16 | |
1992 Lx
11.39@119.24
its based off interweb reading duh!
#17 | |
With that mild of a build i'd go with the 65mm tb and a proflow 75mm or larger calibrated for your injectors. If you think you'll be in the 290 or 300hp neigbhorhood which is the end of the stock 19lb injectors then go with the 24s and get a 75 or 77 proflow calibrated for them. I've ran a cl meter before and had nothing but problems with it.. ran another on another car and it worked ok but never had a problem with prom/proflow meters which is why I suggested them. Could always pickup a cobra 70mm off ebay for like $50 to run with your stock injectors also |
1994 GT
look if u plan on getting heads and a manifold get the 70 mm t/b instead of buying a 65 and have to get a bigger one wen u buy the heads..no point in buying the same part twice..u need to set a plan and know what ur gonna do so u can buy the right part the first time..
Cohagan Engineering, Inc. |
95 opalfrost gt
I was looking for an educated reply, not a sarcastic unintelligent remark. BTW according to some interweb reading the world is going to end in 2012. Will it? probablly not Will a 65mm make more power than a 70mm? probably not. I suggest you get off the interweb once in a while and go experience the real world. Cause as of right now I dont know of anybody who is taking off their 70 or 75mm units and replacing them with 65mm. I guess I could be wrong especiallly if it comes with a guarantee from grnstang. Well i better go I need to swap out my 70mm tbody today its to big and I heard on the internet a 65mm is gaurantueed to make more power.
1993 Mustang
we'll find out when i come home from iraq.
65mm
shut up before i punch you in the throat |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/98297-what-size-throttle-body.html
| what size throttle body ? | This thread | Refback | November 21st, 2008 04:32 PM | |
Threads Similar to: what size throttle body ?
| Throttle body size | new2mustangs | 99-04 | 8 | October 6th, 2008 12:02 AM |
| throttle body size? | jonboy2389 | 5.0 Mustangs | 17 | May 31st, 2008 09:15 AM |
| throttle body size | 1fast5.0 | 5.0 Mustangs | 0 | February 6th, 2008 07:12 PM |
| Throttle Body Size | 95blackbeauty | 94-95 | 13 | December 27th, 2007 03:33 PM |
| What size throttle body? | Euroeater95 | 94-95 | 1 | July 6th, 2007 04:29 PM |
