Thoughts on turbo charging a carbureted motor
Old November 21st, 2008, 09:47 PM   #1
87stang_5.0's Avatar
1987 mustang hatchback
N/A
87stang_5.0 is on a distinguished road
See in the next year I am boring my 302 out. I don't know what I want to bore it out to but I want to twin turbo it afterwards. Which bore kit and turbo system would be best.
Old November 21st, 2008, 10:26 PM   #2
nolife's Avatar
91GT, 88GT, 02GT
Keep in mind a stock block is good for 500-550 crank HP. I would hope any twin turbo kit would be able to get to that level. That being said, your block would be on borrowed time at that HP level so putting any money into it might not be a good idea.
Old November 21st, 2008, 10:44 PM   #3
N/A
What are some good mods that will help reach that 550 hp limit other twin turbo.
Old November 21st, 2008, 11:00 PM   #4
mustangsoldier's Avatar
1993 Mustang
we'll find out when i come home from iraq.
mustangsoldier will become famous soon enough
full bolt ons and nitrous or a big blower. but make sure you dont forget to upgrade the suspension. no point in making 500whp if youre not putting it to the ground...
shut up before i punch you in the throat
Old November 21st, 2008, 11:04 PM   #5
2002BLGT is on a distinguished road
Send a message via AIM to 2002BLGT Send a message via Yahoo to 2002BLGT
carbs are hard enough to get right when NA , much less turbo , you are asking for a headache IMO
Old November 22nd, 2008, 08:52 AM   #6
vfast will become famous soon enough
IMO first you have to wake up from this dream..really.....first the 302 is a waste of time with a turbo, being weak in the lfter valley....A 351 platform would be way more reliable and gives alot more stoker options! all for close to the same coin
EVERYONE IS ENTITLED TO MY OPINION:cool:
6'ers are for kids
1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]*
Old November 22nd, 2008, 02:32 PM   #7
1990 Mustang GT
13.64 @ 101 MPH
GoodOleBoyzRacin is on a distinguished road
go with the big inch windsor. youll be happier. 351 stroked and poked...you could do a fast EFI setup on it but if you want to go the cheap route then id just spray with a carb. alot easier than trying to tune the carb for a blower or turbo.
90 Ford Mustang 5.0 T5- BROKE
1.9 60' on street tires13.64 @ 101 MPH
89 Ford Mustang coupe- http://www.youtube.com/watch?v=1nIrzcQz3_8
Old November 22nd, 2008, 09:16 PM   #8
1986 LX
none yet
jtyson8602 is on a distinguished road
everyone always says its harder to tune a turbo carb than efi. I say BULLSHIT. Now if this is a daily driver, stay efi and go with a 351w base. But if this is a track car, go carb! If youre stuck on stock block do step up to the 351 though. As for tuning, with a good modified carb or special made carb for blow through, tuning can be simple. with efi unless you own a dyno and all the software and hardware needed to tune, you wont be doing any of it yourself. With the carb you can mess with it to get it where you like it without a trip to the local shop.
Though I am a little biased seeing as I run a blow thru set up. EFI is easier for the DD but I like tunability on my time so carbed works for me
Old November 23rd, 2008, 10:53 AM   #9
Racinjason81 is on a distinguished road
if its not your daily driver definitely do a blowthrough turbo setup just do a single turbo if you want more room and spend less money.check out turbomustangs.com if you want more information.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Threads Similar to: Thoughts on turbo charging a carbureted motor
EFI to carbureted? rusty2407 5.0 Mustangs 24 October 22nd, 2008 08:14 AM
Turbo on my 07? Have a look for thoughts TDog 2005 - 2010 11 January 25th, 2007 03:28 PM
Fuel Injection or Carbureted? jtillery 5.0 Mustangs 7 January 15th, 2007 04:41 AM
Carbureted PVC System smbikes 5.0 Mustangs 8 November 13th, 2006 09:24 PM
