#21 |
13.64@101mph
look into the trick flow valve spring upgrade for the cast iron heads..they are like $133.95..and supposed to handle the lift of anything upto .542" lift..like the tfs stage II...and something like .600" lift for the twisted wedges...plus comes with the retainers, keepers, shims etc...
#22 |
13.64@101mph
yeah that setup probably would benifit from a 65mm tb over the 70mm..try and find someone to trade you..alot of people look to go up sizes...not down..shouldnt be too hard
#23 |
1992 Lx
11.39@119.24
mail me the 70 and mail you my 65mm
#24 |
13.64@101mph
see...took twenty minutes and you didnt even have to do anything
#25 |
1988 Mustang GT / 98 Expo
So i got my heads Xmas eve, and the casting #'s are F3ZE AA and off an explorer. What is the combustion chamber size of these heads.
How much would i need to have these milled to get them to give me a 9.5:1 compression ratio. what else could i use on this set up, I also will be be porting out the exhuast runners for better flow.
mods list: Balanced 306, Cobra intake, GT40 heads, TFS1, 1.6 RR's, 70mm TB, 73mm ProFlo MAF, BBK shorties, OR/H pipe, Flowmaster American Thunder cat back, 3:73's, MAF Conversion, CAI, A/C and Smog deleted,
#26 |
Get some new spring........
PeteAndersonRacing.com |
#27 |
1988 lx
9.68@142
be real careful and if it doesnt take you at least an hour on each port your not doing it right. get an old header gasket and spray paint dont go any bigger then the outline and be carefun on the lip cause the water ports arnt that deep down on that heads.. i have ported a set of gt40's and steel heads suck ballz to port.
#28 |
IMO it's not worth porting the exhaust side, especially on heads that are so limited in terms of intake flow. Spend the time instead blending the short side radius on the intake and smoothing out the pockets.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
#29 | |
1990 LX hatch
Hell yea they do> Here is a set I did. Knife edged the guide a lil. ![]() intake runners. ![]()
#30 | |
What bits did you use to do your porting?
#31 |
1990 LX hatch
Carbides. Sanding rolls, and cross buffs from Standard Abrasives.
#32 |
1988 lx
9.68@142
you did a good job looks clean. ya i have 2 carbides and they are great but there is really nothing else you can port steel with..
#33 |
1990 LX hatch
Yea, I went through a few bits. Stones dont work at all. It takes a while to make progress.
#34 |
1988 lx
9.68@142
ya stones dont work yjey wear out too fast
#35 |
1994 GT
i would keep the 70mm t/b on for sure..specially since your putting your heads and cam in
Cohagan Engineering, Inc. |
#36 |
Hey guys it's been a while but i just got the car all done heres a lil vide of it
#37 |
Nice setup!
I just got done doing my P head swap.. nearly Identical setup to you. GT40P's, 65mm tb, MAF, bbk shorties, o/r h, flowmasters, cai, underdrives, 1.6rr's, tfs 1 cam.
weeee foooord!
#38 |
Heres some more pictures
Threads Similar to: begining the rebuild
| the rebuild! | mustangfu | 5.0 Mustangs | 3 | May 17th, 2008 06:59 PM |
| Considering a Rebuild | LikeYouStoleIt | 5.0 Mustangs | 4 | April 30th, 2008 11:35 AM |
| My TA after the rebuild. | Blackbird1084 | Videos | 2 | April 12th, 2008 12:40 PM |
| To rebuild? | hudini | 4V / SVT | 2 | September 30th, 2007 09:47 PM |
| Rebuild or Not to Rebuild? | JERSEYTHUNDER | 5.0 Mustangs | 1 | July 26th, 2006 11:39 AM |
