begining the rebuild
Old November 21st, 2008, 09:59 PM   #1
foxbdy88's Avatar
1988 Mustang GT / 98 Expo
foxbdy88 is on a distinguished road
So i tore down my engine tonight this is what i have found
Have no idea what that stuff is but it came from the oil pan which is prolly
why i had low oil pressure
One of the main bearings they all had copper showing
Rod bearings are pretty much all the same with copper showing
mods list:
Balanced 306, Cobra intake, GT40 heads, TFS1, 1.6 RR's, 70mm TB, 73mm ProFlo MAF, BBK shorties, OR/H pipe, Flowmaster American Thunder cat back, 3:73's, MAF Conversion, CAI, A/C and Smog deleted,
Old November 21st, 2008, 11:58 PM   #2
3521's Avatar
1988 Gt Cali car
3521 is on a distinguished road
ouch looks like the extra engine I pulled apart
Old November 22nd, 2008, 01:45 AM   #3
Brian@PAR's Avatar
Brian@PAR is on a distinguished road
So what are your plans for the rebuild? It is often more cost effective to replace parts rather than have them worked. Case in point. If you plan on having ARP rod bolts installed you need to have the rods re-sized. I assume from what I see it will need to be bored so you are looking at a balance anyway and it's probably cheaper to replace the rods then to have them re-sized.
I'm sure the crank needs to be cut and if the areas where the seals go are scored it may be cheaper just to replace the crank with another cast unit. Here it's 100.00 to cut the crank and another 50 or so to sleeve the seal area. You can replace it for 240 or so and you have something that is still serviceable god forbid you spin a bearing a year from now.
PeteAndersonRacing
Old November 22nd, 2008, 11:38 AM   #4
78mach1's Avatar
78mach1 is on a distinguished road
Send a message via MSN to 78mach1
that crap on your lower intake looks like what i refer to as baby sh**....
this occurs when oil and coolant get thrown threw a 5.0 blender
Old December 3rd, 2008, 10:35 PM   #5
foxbdy88's Avatar
So im going to be doing a budget build for a my daily driver and this is my first time build. The block will be cleaned with all new bearings, lifters, hardend pushrods, Oil pump and hardend shaft, Main gridle, windage tray and etc... So i need some Ideas for a budget combo.
Ideas
Cobra, GT40, Typhoon, Intake
Port my E7's or get GT40's
1.6 RR's or 1.7RR
TFS1 cam (51402000)
70mm TB
Things have so far:
BBK shorties
BBK OR/H
Flowmaster cat back
CAI
BBK Regulator
3:73's
MAF Conversion
ADS superchip
24lb injectors
190lph Walbro fuel pump
Any thoughts would help, like I said it will be my first build
mods list:
Old December 3rd, 2008, 11:14 PM   #6
flattusmaximus78's Avatar
1993 5.ohhhh
12.97 @140mph
That set up should be good for some 13.0s id say go for it. But if your ganna stick with an iron head go gt40
02 Pewter z28, hoosiers/lid/exhaust/spray...125mph 1993 gt Sold, already missed
--Moates Quarter horse $225--
--Cobra intake $150--
--tremec 3550 bell and shifter $1100--
Old December 3rd, 2008, 11:39 PM   #7
Brian@PAR's Avatar
What he said. That will be a great street motor. It'll feel really fast have a little lope but not give you any problems driving it day to day.
As far as the heads. IMO it's not worth porting E7's especially if you have to ship them somewhere. If you can find GT-40's for a reasonable price then that is the way to go but keep in mind that you can get performance irons, that will blow away a GT40 for 1073.00 (from us) so don't dump 8 or 9 hundred bucks in a set of stock castings.
And stock springs will not work with that cam. I used a TFS 1 with a set of "upgraded" springs that were slightly stiffer then stock and had a 6K revlimiter due to valve float. Make sure you budget in the springs and any other mods you'll need for the heads before you make a purchase.
1.7 rockers would be a good idea but you have to think if that is what you're gonna want to run down the road. A good set of rockers can move from head to head (assuming you are going to go to studs) so spend that $275 once and get something you can reuse on the next build.
PeteAndersonRacing
Old December 3rd, 2008, 11:52 PM   #8
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
yea thats definitely looks like oil and coolant that sat together for a while
Cohagan Engineering, Inc.
Old December 4th, 2008, 10:25 AM   #9
91 LX
13.7@101
that isnt as bad as the 350 we just pulled out of my buddies ride ; D. haha but yeah...your ideas look good, and the best thing to do with your e7's would be to sell them or scrap lol
Old December 8th, 2008, 01:03 AM   #10
foxbdy88's Avatar
What kind of springs should i look into? or would it be more cost efficent to use 1.6 RR's?
mods list:
Old December 8th, 2008, 01:45 PM   #11
Atomized
gotn20's Avatar
gotn20 will become famous soon enough
dude for real you shouldn't just re ring that motor. Trust me dude I'm the king of the ghetto re ring budget build but that motor looks like it needs to be sleeved or bored. And I would at least have the crank looked at.
Old December 8th, 2008, 01:59 PM   #12
Speedstang302's Avatar
13.64@101mph
Ideas
1.6 RR's or 1.7RR
TFS1 cam (51402000)
70mm TB
Things have so far:
BBK shorties
BBK OR/H
Flowmaster cat back
CAI
BBK Regulator
3:73's
MAF Conversion
ADS superchip
24lb injectors
195lph Walbro fuel pump
whats the cobra your putting in this? do you not realize the 93 cobra motor is same everything minus heads, intake, cam, tb, maf that bull crap...same block, same internals..i wouldnt waste ur time on the professional products parts..i havent heard much good about them..you can find a stock cobra/gt40 intake for under 200 used..will make same if not better numbers than the typhoon...and its not jap made...if you are looking for a basic street engine..try this
try and find someone to bore that block .030 over...throw some basic .030overbore pistons and the stock rods and crank back in...try and get some gt40p heads..use a gt40/cobra intake, use your tfs cam you want or look at a nice anderson cam...you dont exactly need 1.7 roller rockers for that mild a motor.. then just add you tb, maf, and fuel pump and you might have to get a set of headers that will work with the gt40ps..but that set up is pretty cheap and with traction is good for 12's all day
1990 GT- GT40p Heads| Anderson N41 cam| Crane 1.6 RR's| Trickflow Intake|MGW Short Throw| Aluminum d/s| 3.73's.....still slow....
Old December 8th, 2008, 02:43 PM   #13
1992 Lx
11.39@119.24
the combo youre gona build is basically my motor, except im on stock rockers and an explorer intake
Old December 8th, 2008, 03:32 PM   #14
baine21225's Avatar
+1, but i think i'd make it a 347 while it is apart
Old December 9th, 2008, 04:17 PM   #15
13.64@101mph
yeah wouldnt we all if we had the money..if you cant afford the new rods and crank...just do the 306...
Old December 12th, 2008, 01:30 AM   #16
foxbdy88's Avatar
LOL I agree. If had the money i would build a street killin machine. But im not really looking for that just want some more power for a daily driven beast. well parts list looks like this and growing:
I got
Cobra intake
GT40 heads
70mm Throttle body
BBK shorties
BBK OR/H
Flowmaster cat back
CAI
BBK Regulator
3:73's
MAF Conversion
ADS superchip
24lb injectors
Still need
Roller rockers
TFS1 cam
Oil pump w/ hardend shaft
24lb MAF
Motor/trans mounts
Water pump
Gaskets, Hoses
Bearings, rings, block cleaning and inspection etc...
Any ideas will be helpful..
mods list:
Old December 12th, 2008, 01:32 AM   #17
foxbdy88's Avatar
Did you tune yours? What did you do for your final set up to get ponies where their at?
I like the sig too... LOL
mods list:
Old December 12th, 2008, 10:19 AM   #18
91 LX
13.7@101
hey get a 65mm TB you will make more power than the 70 trust me
Old December 12th, 2008, 11:07 AM   #19
foxbdy88's Avatar
I already picked up a 70mm for $50
mods list:
Old December 12th, 2008, 11:09 AM   #20
foxbdy88's Avatar
I got my heads on the way and i need some guidance in the valve spring world. What springs (Specs) should i look into to handle the TFS1 cam?
mods list:
Threads Similar to: begining the rebuild
the rebuild! mustangfu 5.0 Mustangs 3 May 17th, 2008 06:59 PM
Considering a Rebuild LikeYouStoleIt 5.0 Mustangs 4 April 30th, 2008 11:35 AM
My TA after the rebuild. Blackbird1084 Videos 2 April 12th, 2008 12:40 PM
To rebuild? hudini 4V / SVT 2 September 30th, 2007 09:47 PM
Rebuild or Not to Rebuild? JERSEYTHUNDER 5.0 Mustangs 1 July 26th, 2006 11:39 AM
