fuel how much is too much?
hi i have a 5.0 that im going to swap to a 351 and probably down the line stroke it to 408. stock injectors are 19lbs right? if i am running n/a how high should i go? i was alreadly planning on replacing stok pump for 255lph just in case i go up to more aggressive mods. i was looking around at what other guys are running and i was thinking 36 or 42 lb injectors but i dont want to get them and realize when i put them in that im working them too hard.
1990 LX hatch
I'd start out with 30# then head for the dyno
if this 351 is in stock form with say a mild cam 24's will work nice with a 70mm t/b and a 76+mm maf
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
you should base your decision on horsepower goal. 42s are good for a little over 500hp.
definitely install the 255lph fuel pump.you should install an adjustable FPR too
1994 GT
u definitely need a bigger pump and a regulator but dont buy injectors that are jus right..get some that are gonna leave you some room to grow
Cohagan Engineering, Inc. |
shit I would just use a carb if the stoker is just around the corner
Threads Similar to: fuel how much is too much?
| OEM located fuel cell / replacement fuel tank | carloverx | 5.0 Mustangs | 10 | June 20th, 2008 08:15 PM |
| Race fuel in with stock fuel delevery systems | red2k2gt | Modular Mustangs | 3 | January 25th, 2008 05:36 AM |
| Race fuel in with stock fuel delevery systems | red2k2gt | 99-04 | 6 | January 4th, 2008 05:20 PM |
| Lucas fuel injector cleaner and fuel filter | Saleen0101 | Modular Mustangs | 0 | September 25th, 2007 03:09 PM |
| HUGE PROBLEMS....IDLE, AIR/FUEL/FUEL PRESSURETPS HOW TO SET? | 1slowhatch | 5.0 Mustangs | 0 | April 21st, 2007 06:48 PM |
