Question about 3g alternator upgrade
LinkBack (1) Thread Tools
Old December 1st, 2008, 10:50 AM   1 links from elsewhere to this Post. Click to view. #1
noyz25 is an unknown quantity at this point
Can i just buy a autozone 95 mustang alternator or do i need to order it from like PA performance?
Also those 3g one wire alternator are they easier to install because of the one wire set up or not? What are the cons and pros of going one wire?
Thank you
Old December 1st, 2008, 11:26 AM   #2
USMC8511's Avatar
1990 MUSTANG GT
13.55 @100.64
USMC8511 will become famous soon enoughUSMC8511 will become famous soon enough
I bought a whole upgrade kit from a guy on Ebay that makes them.... it was easy and cheaper than just going and getting one from autozone...
Old December 1st, 2008, 11:55 AM   #3
1992 Lx
11.39@119.24
link?
Old December 14th, 2008, 03:56 PM   #4
bump TTT
Old December 14th, 2008, 07:20 PM   #5
baine21225's Avatar
bump
Old December 30th, 2008, 01:45 AM   #6
Bunp Ttt
Old December 30th, 2008, 02:17 AM   #7
I bought a brand new 3g 130 from autozone with the life time warrenty...... cut the harness out of a 94 in the junkyard and haven't had any problems since. If and when it fails i can just return it for a new one at any autozone
If you want it to fit within the stock alt bracket without having to hack up the bracket make sure it's a small case 3g alt which I think only came on sn95 stangs in 94 and 95
Also don't forget you have to upgrade the charge wire to at least a 4 gauge and do the same to the ground or you could cause a fire
Old December 30th, 2008, 02:57 AM   #8
e3sean's Avatar
1988 lx
9.68@142
e3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the roughe3sean is a jewel in the rough
i bought a 95 mustang 130 amp alt from autozone it will wire up to the stock wireing you just have to cut and splice some wires. also get a 4 gauge wire to run from the altornator to the battery. the only thing you have to do is grind the bracket a little.
<font size=4><b>MILITARY CREW
Old December 30th, 2008, 06:56 PM   #9
BLUE91GT's Avatar
BLUE91GT is on a distinguished road
3g Alt
I just installed my 3G from PA performance, and what a difference it made. 130 amp and it puts out 80 amps at idle. I had to run a new power wire from the altonator to the solonoid. It was a much heavier guage than the stock wire. With everything on I am putting out between 12.8 and 13.5 volts at the battery which is in the trunk, and around 15.5 right out of the altonator. See list below. Next will be electric fan and water pump.
1 heater full speed
2 winshield wiper full speed
3 rear defoger
4 head lights
5 fog lights
6 stereo
Old December 30th, 2008, 09:55 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Thank you
Any 3g alternator can be adapted to a fox body.
Old December 30th, 2008, 10:00 PM   #11
e3sean's Avatar
1988 lx
9.68@142
just make sure if you get a 95 stang alt you get a stock mustang pully or it aint gonna do shit.the 95 has a bigger pully and i have yet to switch it lol.
Old February 24th, 2009, 01:55 AM   #12
Well just ordered my turbo kit, Digi 6AL, and alt. relocate kit so now i'm gonna buy the alternator finally and was wondering which harness to order.
86 CONVERSION WIRE, 5.0, 2G TO 3G MUSTANG
CONVERSION REGULATOR PLUG, 2-WIRE TYPE ONLY MUSTANG
Old March 1st, 2009, 12:31 PM   #13
bump ttt
Old March 1st, 2009, 04:05 PM   #14
1998 Cobra
13.24@105.66
what if your not running the factory voltage wires and all that stuff. Can I just ground it to the chassis and run the one wire back to solenoid and be done with it?
weeee foooord!
Old March 1st, 2009, 05:44 PM   #15
Change all the wires...... Two wires go straight to the solenoid ... The main charge wire I would suggest going to at least a 6ga and the other wire a 10ga .... one goes to the ignition wire....and one wire on the alt is a jumper wire.
PeteAndersonRacing.com
Old March 1st, 2009, 07:32 PM   #16
1989 LX coupe 5.0L
89lx is on a distinguished road
Ford Mustang: Mustang Tech: Electronics and Ignition: 130 Amp 3G Alternator Install
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/99595-question-about-3g-alternator-upgrade.html
Question about 3g alternator upgrade This thread Refback December 15th, 2008 07:17 AM
Threads Similar to: Question about 3g alternator upgrade
3g alternator upgrade jtyson8602 5.0 Mustangs 11 November 9th, 2008 09:23 PM
Question (Alternator) Stang187 V6 Mustangs 3 December 18th, 2007 09:42 PM
Alternator Goin Out... Time For 3G Conversion? Info On Good Upgrade Iwannagofast 5.0 Mustangs 96 December 11th, 2007 12:16 AM
best alternator upgrade redponygt 99-04 1 May 4th, 2007 11:38 AM
1988 5.0 alternator upgrade QQQQ 5.0 Mustangs 5 March 3rd, 2007 01:23 PM
