Stock head and Intake Porting
Old January 8th, 2006, 03:48 PM   #1
GizmosMustang's Avatar
GizmosMustang is on a distinguished road
Send a message via MSN to GizmosMustang Send a message via Yahoo to GizmosMustang
ok how much horsepower can be gain by porting the stock heads and stock intake? and adding the ford racing e cam?
Old January 8th, 2006, 04:32 PM   #2
I'd say 50-60 depending on how well the heads flow afterwards.
88 Mustang Coupe
www.rickscarcare.net
Old January 8th, 2006, 04:33 PM   #3
ok that sounds good how about if i stroke the motor to a 347 how much power will be gained over the stock motor?
Old January 8th, 2006, 09:53 PM   #4
you gonna need more than a e-cam for a 347
88 Mustang Coupe
Old January 8th, 2006, 09:54 PM   #5
alright what size cam don't wanna be to wild though just enough
Matt
Old January 8th, 2006, 09:55 PM   #6
mdvaldosta's Avatar
11.47@120.58
Trash the intake. The heads can be made to flow OK, but the intake won't. Really, it's not a flow problem with the intake, it's the runner design and that the intake is built to perform under 4500 rpm. Your gonna need an aftermarket intake to take advantage of higher RPM breathing or your entire package will suffer.
Old January 8th, 2006, 10:01 PM   #7
well what i'm looking for is more power but retaining a stock look
Matt
Old January 8th, 2006, 10:14 PM   #8
mdvaldosta's Avatar
11.47@120.58
You'll be wasting a head porting if you keep the stock intake. I'm not sure what the hangup is for keeping it stock looking, if you absolutely insist on keeping the stock intake then spending some bank (more than what it would cost for a better aftermarket unit) you could have someone cut open the stock intake, shorten and work the runners, and weld it back.
Old January 8th, 2006, 10:34 PM   #9
FastFiveO's Avatar
FastFiveO is on a distinguished road
Send a message via AIM to FastFiveO Send a message via MSN to FastFiveO Send a message via Yahoo to FastFiveO
GT-40 P heads GT-40 intake and you will be doing fine. stock heads have some small valves to begin with and a stroker is a lot of money for a small power boost.
86 Mustang GT- twinturbo nitrous injected and much more.
86 Bronco- few mods
Old January 9th, 2006, 08:30 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You will gain more from a good set of heads. E7s ported or not will be your bottle neck especially with more cubic inches. Stick the money into a good set of aftermarket heads such as a set of Twisted Wedges. Good heads are the key to making good power. Even the best ported E7s don't flow as good as a good aftermarket head.
Old January 10th, 2006, 02:30 AM   #11
The hang up is this Car is an SSP I wanna keep a Stock appearance because of show quality and everything if i can gain horse power with out going into more expensive heads and intake that don't look stock. i want as much power as possible with stock components like the heads and intake but the stock block will remain in the car for now but maybe in about a year or two and then will be pulled for a new sportsman block from ford racing So as of now I want as much power out of the stock block and components as possible.Thats the hang up with me buying a whole new intake and heads!
Matt
Old January 2nd, 2007, 03:34 PM   #12
tmoss's Avatar
tmoss is on a distinguished road
You can use GT40P heads and a ported stock upper/lower intake. The port3eds tock intkae when properly done can flow 190-200cfm which is a great match to the P heads. Power should be 260-280RWHP if a good cam is installed.
Old January 2nd, 2007, 05:02 PM   #13
TurboLX's Avatar
1988 Mustang LX Turbo
upgrade to the fox cobra intake i believe that was the only diffrence between the stock 5.0 and the cobra 5.0
which had a 25 hp diffrence
Old January 5th, 2007, 12:29 PM   #14
is there a type of paint i can buy to put o the heads to make them appear to be stock?
Old January 5th, 2007, 01:39 PM   #15
OTreborO is on a distinguished road
show car
If it is a show car, and there are really Mustang freaks there, they will know no matter how much Kylon you spray. I think you need to decide to leave it alone or go for it.
"Those who forget the past are condemned to repeat it" Rev. Jim Jones
Old January 5th, 2007, 02:02 PM   #16
Darrellx14's Avatar
Darrellx14 is on a distinguished road
If i were in you're shoes, I'd build that bitch bad, and just keep all the factory components incase you ever wanted to put the engine back to stock to keep the SSP value so to speak. Doesn't that sound like an idea?
Old January 5th, 2007, 02:19 PM   #17
thought about that and might end up doing it
Old January 5th, 2007, 03:40 PM   #18
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
If you really want to keep it stock looking and dont mind wasteing a few bucks.(JMHO) Then have the e7s ported http://www.thumperoforangepark.com/ and get in touch w/ Tmoss at http://www.tmossporting.com/ to have the intake done. With a well matched cam youll be looking at a nice power increase and still retain the stock look. The big ? is will this satisfy your HP Quest? Trying to keep all the stock parts for looks is going to limit your HP potential.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old January 5th, 2007, 04:16 PM   #19
82GT is an unknown quantity at this point
I have a set of early 351w heads that are ported & polished with 1.94/1.60 valves I would sell you. They have 60cc chambers.
1982 GT (t-top)
351w(.060),10:3, ported & polished iron heads, 1.94/1.60 valves, BBK shorties & flowmasters, 274XE cam, stealth intake, mallory dizzy, stealth intake, 750dp, Edge 3700 stall converter, C-4, 4:10's
Best E.T 12.85@102mph
Old January 5th, 2007, 05:53 PM   #20
notsoslo5.0 is on a distinguished road
ballpark range how much is it to get gt40p's ported? and would they work good with a trickflow street heat upper lower and 70mm
Threads Similar to: Stock head and Intake Porting
Head Porting Services 98BlackBeast Modular Mustangs 1 August 13th, 2007 08:33 PM
DIY cylinder head porting 99v6stang V6 Mustangs 9 July 25th, 2007 09:59 PM
porting stock intake manifold 99GT281 99-04 10 March 22nd, 2007 09:39 PM
Head Porting Questions! 96greenGT 99-04 13 November 14th, 2006 10:21 PM
Head Porting Info IcantDo55 5.0 Mustangs 3 September 4th, 2006 11:40 AM
