1993 Mustang LX 5.0
Ignition problem
My 93 mustang lx has a wierd problem...Occassionally when I turn the key to start the car the oil light, check engine light, stereo doesn't come on, power windows don't work, ac doesn't work...Then when I turn the key back ever so slightly everything has power and is back to normal and I do notice that it is hard to turn the key to the off position...And it's not an every time thing it happens probably half the time I start the car....Anyone know what this might be?
Authorized Vendor
![]() Join Date: Sep 2008
I'd first suspect an issue with the ignition switch itself.
Sounds like the common fox body ignition switch issues. There was a recall on them at one point in the 90s. Chances are yours is bad.
1993 Mustang LX 5.0
haha great! I lovee recallss...Is there a lifetime recall repair thing or do I just have to pay to fix it?
I don't know if the recall is still in effect. Replacing the switch is fairly easy.
1993 Mustang LX 5.0
Ok i'll check up on it thanks
Threads Similar to: Ignition problem
| Ignition timing problem..... | 93mustank | 5.0 Mustangs | 18 | December 2nd, 2008 09:28 PM |
| 1983 ignition problem | Wook660 | 5.0 Mustangs | 0 | October 10th, 2008 12:07 PM |
| ignition problem with my other vehicle | 92_LX_5.0 | 5.0 Mustangs | 2 | November 8th, 2007 10:15 PM |
| is there anyway to get away for the ignition problem | gordon norris | 5.0 Mustangs | 4 | February 19th, 2007 09:34 PM |
| Ignition problem? | 86blkmustang | 5.0 Mustangs | 15 | February 7th, 2007 08:55 PM |
