Heavy Clutch
Old December 18th, 2008, 11:56 AM   #1
64 289 CP & 94 Cobra CP
usmc20c is on a distinguished road
Send a message via MSN to usmc20c Send a message via Yahoo to usmc20c
Heavy Clutch
When pressing in the clutch it feels pretty heavy when compared to other cars... what would cause this and is this normal ???
Old December 18th, 2008, 12:38 PM   #2
95stroker's Avatar
1995 Mustang GT
95stroker is on a distinguished road
Well if its an aftermarket clutch, that could just be how it is. You could have a bad pressure plate, that can do the same thing. The throw-out-bearing can cause it too I think. I'm sure some others can correct me if I'm wrong.
Old December 18th, 2008, 12:52 PM   #3
94BLKGT is on a distinguished road
You could also have a binding Clutch Cable also. You are right some of the Aftermarket clutches will have a stiffer pedal feel then a stock unit. The TO bearing will also make a little whirring if its starting to go out.
Old December 18th, 2008, 01:43 PM   #4
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
the tob wont make it stiff..make sure the cable is routed correctly..ive also heard of certain cables are just strait garbage..what cable do you have? i need a little more description when u press the pedal down...does it just feel heavy but moves freely?..does it feel different at different points(at the top, middle, or floor).
Cohagan Engineering, Inc.
Old December 18th, 2008, 03:00 PM   #5
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
stock the mustangs clutches are naturally harder to push down than most cars. its possible that there is nothing wrong at all. and if you have a cobra it is even harder to push down than a GT (im just going off of the numerous mustangs ive driven in the past)
Old December 19th, 2008, 01:34 AM   #6
smott's Avatar
1994 GT
11.75@120
smott is on a distinguished road
agreed +1 ^^
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers...
E/T: 11.75 @ 120mph 2.0 60foot
Threads Similar to: Heavy Clutch
03/04 SVT Cobra-heavy clutch Terminated675 4V / SVT 30 November 20th, 2008 08:49 PM
Heavy GT Emay 2005 - 2010 89 November 10th, 2008 08:36 PM
clutch getting heavy stang1101 4V / SVT 8 July 28th, 2008 11:24 AM
Heavy clutch stevo92gt 5.0 Mustangs 5 November 4th, 2006 02:11 PM
need heavy tuning stangmasta306 General Tech 1 April 20th, 2006 07:54 AM
