Discussing 302 to 306 conversion in the 94-95 Forum. I am looking into doing a 306 on my 95 gt. Right now the engine ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
I am looking into doing a 306 on my 95 gt. Right now the engine is stock with cold air intake and about 80000 miles on it. Should I just go with a new 306 block or work with the stock block and buy the rotating kit and I am looking into using theTrick Flow Twisted Wedge 5.0L EFI Engine Kits
TFS-K514-350370B. Unfortunately the car doesnt run right now. The brAND NEW Optima battery I put in keeps draining and the car wont start I had the alternator changed and now Im going to do the starter. Where would the best place to start be? Im looking to spend around $5000 for this setup. Does that seem reasonable for what I want to do? I am just starting to work on the engine. any advice would be very helpful thanks craig |
95 opalfrost gt
If all your going to do is the 306 with a TFS kit the stock block would suffice. A rotating assembly from CHP or the likes would be the way to go. If you plan on a power adder w/ the 306 then you should look into an aftermarket block IE.. DART, Man of war, or the new boss block. Good luck w/ it.
Threads Similar to: 302 to 306 conversion
| 2v to 3v conversion??? | droppedbass87 | 96-98 | 22 | November 2nd, 2007 01:36 PM |
| conversion | Mustang RacR94 | 99-04 | 8 | April 3rd, 2007 12:02 AM |
| 2.3L to 5.0L conversion | stan_doe | 5.0 Mustangs | 6 | January 23rd, 2007 02:39 AM |
| 99-04 V6 To GT Conversion ?'s | ineedajob | V6 Mustangs | 7 | November 9th, 2006 05:18 PM |
| After A 5 Lug Conversion... | 347tt | 5.0 Mustangs | 7 | September 28th, 2006 04:53 PM |
