2000 mustang GT
brake problem!!!
ok, so i was on my way home from work and when i get to the entrance to my neighborhood i proceeded to stop as i normally would when my pedal drops all the way down and i barely get the car to stop, then i noticed that smoke started commin out of the from under the car. i think i might have a rip somewhere in the line bc when i pump the brake i still have good pedal feel, but when i just press down on it it just drops all the way down. HELP me ASAP
1994 Mustang GT
I just fixed mine. Had the same problem after i did some front end work. The easiest thing to do is look for a puddle of brake fluid under the car. The smoke is probably from it hitting the exhaust. I used some compression fittings to fix mine and it worked great. It cost me $3.00 and took about 10 min. to fix once i found it. The size of the brake line is 5/16"
2000 mustang GT
were do they sell those? how do i use them
1994 Mustang GT
shoot me you email and i will send you a sketch. It's easier to see than to explain.
1994 Mustang GT
check here for installation instructions:
Compression type fittings from the PlumbingStore |
1994 Mustang GT
I got the parts at auto zone
2000 mustang GT
its kool fixed the leak and i heard that if you have to much pressure in your line the compression fittings could pop out.
1994 Mustang GT
Glad to hear you got it fixed. The compression fittings are bolted together, so they can't pop out. They compress a flange onto the brake line. Anyway, I'm glad you got it fixed. Was it something simple?
85 GT/86 SVO/2010 GT500
Threads Similar to: brake problem!!!
| Brake Problem | turismo374 | V6 Mustangs | 3 | April 16th, 2008 06:58 PM |
| Brake light switch problem after upgrading brake booster | black88 | 5.0 Mustangs | 2 | January 21st, 2008 12:41 AM |
| brake problem | 00redgt | 99-04 | 3 | January 5th, 2008 09:12 PM |
| brake caliper problem | burnout5.0 | 94-95 | 3 | October 4th, 2007 01:38 AM |
| brake problem | spero | 99-04 | 2 | April 2nd, 2007 07:02 PM |
