Considering a supercharger.
Old January 28th, 2009, 10:33 PM   #1
burnout5.0's Avatar
2004 Mustang SVT Cobra
448whp/475wtq
burnout5.0 is on a distinguished road
hey guys ive been toying with the idea of a kenne bell 2.1L supercharger on my '95 5.0 and i need to know what additional things i will need to do to car for it to run correctly. i only want to run maybe between 6 and 8 pounds of boost. and will i be risking hurting my basically stock motor with the extra power im going to making or should it be okay?
Old January 28th, 2009, 11:26 PM   #2
Traidmarx's Avatar
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
Traidmarx will become famous soon enoughTraidmarx will become famous soon enough
just make sure you got good ignition and fuel components and you should be cool, not a must but to get the most from it, i'd make sure you've got headers and full exhaust, so the motor can breathe good.
1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon.
Old January 29th, 2009, 12:27 AM   #3
The Razor's Edge
White Thunder's Avatar
get a s trim
founder of the FTN Club
Old January 29th, 2009, 09:14 PM   #4
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
you probably won't make as much power with 8 lbs out of a kenne bell as you would with 8 lbs on an s-trim, but if you want a KB, don't let anyone talk you out of it! The people at Kenne Bell are great at getting you set up with everything you need when you go to make a purchase from them. As stated, you will need a more effective fuel system... 255lph fuel pump with an in-line as well and 42# injectors is what I suggest. But I would get in contact with Kenne Bell, and they will hook you up.
Old January 29th, 2009, 09:34 PM   #5
The Razor's Edge
Old January 29th, 2009, 10:03 PM   #6
burnout5.0's Avatar
448whp/475wtq
thanks guys for all the input. still think im gonna go with the kenne bell cause i like the top mount style. if there is anything else i need to know let me know. oh yeah and i have a 70mm TB will that be ok or do i need to get a bigger one?
Old January 29th, 2009, 10:18 PM   #7
The Razor's Edge
Bigger
Old January 29th, 2009, 10:48 PM   #8
burnout5.0's Avatar
448whp/475wtq
ok so so far i need a 255lph fuel pump, 42 lb injectors, and a TB bigger than 70mm anything else?
Old January 29th, 2009, 10:53 PM   #9
Traidmarx's Avatar
1995 Mustang GT
like i said make sure you have quality ignition parts...msd ignition and good set of colder plugs and quality wires., last thing you want is the stock ignition to crap out on you while you're under boost or something.
Old January 29th, 2009, 11:13 PM   #10
burnout5.0's Avatar
448whp/475wtq
cool thanks. and what about a mass air flow sensor?
Old February 3rd, 2009, 02:12 PM   #11
zack065's Avatar
zack065 is on a distinguished road
Send a message via AIM to zack065
woooooooord
Old February 3rd, 2009, 02:32 PM   #12
WildWill's Avatar
1995 Mustang GT
NOT msd ignition... stick with replacement factory parts. msd is junk IMO.
Old February 6th, 2009, 07:05 PM   #13
TKOTLARZ's Avatar
1994 GT
TKOTLARZ is on a distinguished road
yea u will need one to be calibrated for the injectors..make sure u have a CAI to go with the exhaust..if ur letting more air out, u need to let more in
Cohagan Engineering, Inc.
Old February 7th, 2009, 12:35 AM   #14
burnout5.0's Avatar
448whp/475wtq
cool i actually called kenne bell and they told me with 6 to 8lbs of boost that 36lb injectors and 255lph pump should be good and that i can keep the stock MAF as long as i get a tune. i think ill get the MAf anyway. i forgot to ask about the TB. but i already have a 70mm i think that might be ok.
Old February 7th, 2009, 10:01 AM   #15
WildWill's Avatar
1995 Mustang GT
Yeah since you've already got the 70 mm I woldnt bother to buy another one. The difference in your gains will prob be minimal.
Old February 7th, 2009, 10:04 AM   #16
WildWill's Avatar
1995 Mustang GT
Yeah since you've already got the 70 mm I wouldn't bother to buy a new one. The difference in your gains will prob be minimal
Old February 7th, 2009, 09:58 PM   #17
342pony's Avatar
Looking right now
342pony is on a distinguished road
The s-trim will give you top end power,where as the KB will turn your stang into a torque monster. Can`t go wrong with any of them..
Old February 8th, 2009, 12:22 AM   #18
burnout5.0's Avatar
448whp/475wtq
yeah sounds good looks like i'm gonna start ordering parts this week. what does a tune usually run for what i need?
Old February 8th, 2009, 04:29 PM   #19
WildWill's Avatar
1995 Mustang GT
you can probably get a mail order tune from Kenne Bell (that's what you're getting right? you doing the install yourself?) to get you by until you get a dyno tune from a good tuner. that can run you any where upwards of $400...
Old February 9th, 2009, 12:02 AM   #20
burnout5.0's Avatar
448whp/475wtq
yeah im going with the kenne bell and i might do the install myself not sure yet. it will save me a hell of alot of money.
Threads Similar to: Considering a supercharger.
supercharger ?s angryoriental 2005 - 2010 31 September 20th, 2008 07:30 AM
Supercharger 01brknGT 99-04 7 September 11th, 2008 10:04 AM
supercharger help 94stang 5.0 Mustangs 3 August 14th, 2007 12:24 AM
supercharger 00GT 99-04 4 May 17th, 2007 08:02 AM
supercharger 97_stang_gt 96-98 2 April 20th, 2007 06:52 PM
