Car RPM's Hanging between shifts
Old January 31st, 2009, 07:47 PM   #1
too slow
95blackbeauty is on a distinguished road
Send a message via AIM to 95blackbeauty
I thought my IAC was bad so i replaced it and it still has the problem. It jacks the RPM's up when I push in the clutch between shifts and i cant figure it out. Maybe my TPS? can anyone point me in the right direction? I thought Autozone could pull egine codes on our computers cuz the check engine comes on but they said they couldnt. I think the light is on because of whatever it is making my throttle hang up. Thanks for looking.
95 gt H.O. Udp's, Pypes O/r X, flowmaster 40's,CAI, 3.73 gears, C&L 76mm MAF,GT40p's, Shorties, 1.6 rr's,Gt40 manifold, short throw, Back Seat Delete
BOOSTED
Old January 31st, 2009, 10:47 PM   #2
Racinjason81 is on a distinguished road
a bad tps can cause that
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old January 31st, 2009, 11:45 PM   #3
too slow
changed tps...still happenin
BOOSTED
Old January 31st, 2009, 11:53 PM   #4
Nitrous Injected's Avatar
2003 Mustang GT
13.987@100.98 MPH
Nitrous Injected is on a distinguished road
you may have a slight vacum leak, or you can adjust the throttle blade with th adjusting screw on the side of your TB..i had the same problem and i just cleaned the the throtlle out with TB cleaner and set the TB blade to idle the car around 700-800 RPM. Now the throttle dont semm to stick and the rpms drop normal. also change out all the upper plenum caskets.IAC,EGR,TBS,TB to PLENUM,and PLENUM to intake manifold also check for dead spots in you TBS sensor to make sure that it is difenatly not the problem( you can do this useing an OHM meter...i hope this helps
88 NOTCH,351 WINDSER,BUILT C6 TRANY,750 CFM CARB,4:30 GEAR=??? WWIII
2003 MUSTANG GT SOLD with 488 RWHP and 520 FT-LB on 150 shot and bolt ons R.I.P.
Old February 4th, 2009, 03:06 PM   #5
1995 mustang gt
usmc95gt is on a distinguished road
i know it sounds kinda dumb but have you checked the throttle return spring? my car was doing the same thing and it was just my fault when i changed the throttle body i forgot to hook the spring back up.
Old February 4th, 2009, 11:46 PM   #6
Ryno8705's Avatar
Ryno8705 is on a distinguished road
Do a search over on Corral.net, I did a write up on a few threads about how I fixed the problem you are having... In short, you need an idle air restrictor plate ($15) or listen to all the people who think getting a tune will fix life's problems. If you don't have an account on corral I'll find it and post it here.
Edit, I just found it and here's the link: hanging rpms between shifts - Corral Forums
I did end up buying one on eBay which was stainless steel, but I also made one out of metal duct work.
I posted in other threads on Corral which have further info, just do a search.
Old February 5th, 2009, 09:50 PM   #7
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
^^^ and that guy knows his sh*t, so listen to him! trust me...
Threads Similar to: Car RPM's Hanging between shifts
Average RPM's? Tigerwhite1 V6 Mustangs 6 September 25th, 2008 08:31 AM
Idle Rpm's 96GtGoodz 96-98 19 December 4th, 2007 11:15 PM
Help! RPM's Out Of Control LiiLmiss Modular Mustangs 5 March 26th, 2007 07:45 PM
RPM's not decreasing when off gas smokiebear911 99-04 8 March 1st, 2007 10:31 PM
RPM's & Springs fhinesley 99-04 4 January 28th, 2007 07:24 PM
