1994 Cobra fuel pump limitations?
I was wondering how much power a stock 94' cobra fuel pump will support?
I think they are 155gph? Or is it lph? I'm going to be throwing a 125 shot of nitrous on the 351, and am wondering if the stock fuel pump will support it. Thanks! it's a wet kit, by the way. |
1995 Mustang GT
Your stock cobra pump isn't working as good now 15 yrs later as it did back in '94. That being said just get yourself a 255lph pump and call it done. You will see a HUGE difference in the way your car runs after the swap. I can promise you that. I bought my FP for 100 bucks.
See garage for mods |
How much power will a 255lph support?
1995 Mustang GT
I'm not sure on the exact numbers it will support. There are many guys with blown applications running the same pump so I think it's a safe bet to say you're okay. I think you have to be more concerned with your injector's supporting it. What injectors are you running? FYI, most of the fuel pumps out there are made by Walbro so don't pay extra for a trick flow, bbk, holley etc. When you open up the box it's still going to be a Walbro. Summit lists them for 119.00 You might want to check out Arts Performance and see if he can get you one for around 99.00 shipped. Great guy to deal with BTW!
1995 Mustang GT
slower than a 3 leg dog
not trying to steal the thread but if he were to get a 255 would he need bigger injectors too if he doesnt have them already? or would the stockers be ok?
I have 24# injectors, which might be too small for my 5.8, but doesn't matter for the nitrous kit since it is a wet kit.
To answer your question, no, you don't need different injectors when you swap pumps. |
1995 Mustang GT
I swapped to a 255lph pump and still have the stock injectors... the fuel pump made a HUGE difference, as flamedstang95 said...
I guarantee you're starving your motor with that stock pump. It's totally worth it to swap out the pump. Oh and while you're in there, its a good time to put a new fill neck gasket in. You can only get them at ford for about $40. Guarantee yours will be leaking once you pull the tank out.
1995 Mustang GT
What kind of difference would I expect you say huge but what exactly would it do? In all of the reciepts the previous owner of my car gave me there is one for a new fuel pump but there is no part number or description so I guess I will email him and see if he had a stock one put in. Unless there is an easy way to tell
The Razor's Edge
its not going to be a huge differnece.....but i would highly recomend it
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
its not really a noticable difference if you're car is stock or mostly stock with stock injectors, I just put a Walbro 255lph in my car, not a real noticable difference except the car starts alot easier, thats about all i've noticed really. But you have the peace of mind knowing that if you ever need to step up the injectors to support the power that the pump will be solid.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
1995 Mustang GT
You are probably at the max duty cycle on those injectors. +1 on the filler neck gasket as well.
#12 | |
1995 Mustang GT
Thanks for the info, but does anybody know the limitations of the 255lph pump? Any good links for fuel pump limits?
1995 Mustang GT
If I ever get unbanned from Web Page Re-director I can find the answer for you. You might want to register over there and check out the 94/95 tech. I can't find the exact #'s.
The Razor's Edge
i read some where they wont support more than 60lb injectors....i think...i would like to know the anwser to this as well
Threads Similar to: 1994 Cobra fuel pump limitations?
| 01 COBRA FUEL pump relay | stangpwrd | 4V / SVT | 0 | May 14th, 2008 12:25 PM |
| 01 Cobra Fuel Pump Relay | 01fordcobra | 4V / SVT | 1 | April 4th, 2008 07:43 PM |
| need new fuel pump for '97 Cobra...advice? | jboehle | 96-98 | 6 | January 12th, 2008 10:30 AM |
| 96 Cobra 4V Into 98GT- Fuel Pump? | CI PERFORMANCE | 96-98 | 1 | October 14th, 2006 01:02 AM |
| 1994 Ford Ranger Fuel Pump | DCFD1562 | All Other Vehicles | 5 | September 9th, 2006 06:28 PM |
