Clutch
Old February 12th, 2009, 08:54 PM   #1
Itkix is on a distinguished road
Clutch
I have a heavy duty Ford Racing Clutch, and its supposely new, it seems to be slipping a little mostly in 3rd thru 5th gear, just when I first hit the gear, are the clutches hydrolic if so it may need blead. Any suggestions. Or there any adjustments I can make.
Old February 12th, 2009, 09:46 PM   #2
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
no they aren't hydraulic clutches in these cars... check that your cable is not adjusted too tight. It may be possible that the cable is pulled too tight and is not allowing your clutch to engage fully. def get that checked out soon before you ruin that clutch!
Old February 12th, 2009, 09:54 PM   #3
Ok thanks Ill try that. And I want to change my tranny fluid what type does it take, I've read it takes Auto Tranny fluid. Id like to use some type of synthetic.
Old February 12th, 2009, 10:45 PM   #4
95BlackStang's Avatar
2000 mustang GT
95BlackStang will become famous soon enough
royal purple sounds good, or that synchromesh stuff
00 GT with the heart of a green machine!
99 Electric Green GT R.I.P.
95 GT vert....my first love sold!
Originally Posted by BaznastyDave View Post
99-01 Cobra bumper with Mach spoiler and make all the girls panties wet.
Old February 13th, 2009, 04:26 PM   #5
I got under the car and seems I could just slip the cable right off thats telling me the cable isn't to tight. Had slack in it.
Old February 13th, 2009, 09:23 PM   #6
WildWill's Avatar
1995 Mustang GT
hmmm... new diagnosis anybody??? i don't know a damn thing about clutches, so i'm sorry i cant help you out man.
Old February 14th, 2009, 10:15 AM   #7
flamedstang95's Avatar
1995 Mustang GT
flamedstang95 is on a distinguished road
Have you adjusted the clutch by pushing the clutch pedal in and out? Alot of times after a new clutch is put in it eventually will stretch the stock cable. My suggestion would be to get yourself a steeda double hook quadrant, and firewall adjuster. If you need a new cable don't go to Ford and spend 100+ bucks. You can order a clutch fork kit from summit and it comes with a genuine ford cable...all for around 50-60 bucks.
See garage for mods
Old February 14th, 2009, 11:46 AM   #8
I got under the dash (which will break your neck) and tried to do that adjustment where you pull the clutch back for normal use and then you click it up another notch but I couldnt get it to stay if I was doing it right.
Old February 14th, 2009, 02:23 PM   #9
The guy might have lied to me about it being a new clutch, it seems in 2nd -5th when you change gears and get on it a little it takes a couple of secounds for it to pick up, or is this a tranny problem. I just changed tranny fluid looked good. How do you know when your clutch is going bad I've never owned a car long enought to experience that. Kinda fells like if you hit the 3rd gear and punched the gas you were spinnig tires but its not.
Old February 14th, 2009, 03:21 PM   #10
1995 Mustang GT
If you are experiencing this than it's slipping and your clutch is probably shot. It's so hard to gauge how much life is actually left on a clutch. The guy probably lied to you to put your mind at ease about having to change it. It's really not to bad though, especially easy if you have a lift. When you do decide to swap it out be sure to have the flywheel re-surfaced or buy a new one, and replace the rear main seal. You'll have the driveshaft out too so you may as well have the U-joints replaced too. Take care of it all in one shot. If you don't have the money for a King cobra or Spec 1, etc. the stock replacements at Napa are just fine too. I ran one in my car for about a year and when I changed motor's and the clutch she still had alot of life left on it.
See garage for mods
Old February 14th, 2009, 04:31 PM   #11
The Razor's Edge
White Thunder's Avatar
Yeahs that sounds like a slipping clutch to me. Do like they said and fix what you can the more the better. What mods are you thinking about doing?
founder of the FTN Club
Old February 14th, 2009, 04:35 PM   #12
I dont have a lift just some jack stands I'd like to do it myself because I like to do all my mods. myself. Guess 1st step to get tranny. out.
Old February 14th, 2009, 06:18 PM   #13
onequicktang is on a distinguished road
tranny is easy to get out once the exhaust is out of the way. Did you machine the flywheel when you installed the clutch? Put a center force dual friction in it. That clutch has 85% more clamping force than stock and has less pedal effort than stock. I have one in my 650rwhp turbo stang.
Old February 14th, 2009, 06:45 PM   #14
I didnt put the clutch in but I will get it resurfaced when I put the clutch in, I cant figure out what clutch to get spec, King cobra, ram, centerforce?? I dont want a clutch that makes my leg tired.
Old February 14th, 2009, 06:47 PM   #15
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
I believe the King Cobra is the closest to OE feel. I had one in one of my GT's and it wasn't too heavy. You should look into a lighter flywheel while your in there anyway.
Old February 14th, 2009, 06:56 PM   #16
I dont know about having a aluminum flywheel are they strong.
Old February 14th, 2009, 07:00 PM   #17
HMUSN's Avatar
48.47@ 12.58
iTrader: 11 reviews
strong enough for a geared, tuned, suspensioned, and fully bolted on GT
Old February 14th, 2009, 07:20 PM   #18
Seems like most people dont like the king cobra, Ive been reading threads.
Old February 14th, 2009, 07:38 PM   #19
2000 mustang GT
it all depends on your driving habbits, are you an experienced driver? i read that ppl like to mix and mach diff parts to best suit their needs, but i think that cost more.
Old February 14th, 2009, 08:12 PM   #20
WildWill's Avatar
1995 Mustang GT
i've got a king cobra clutch (well, to the best of my knowledge that's what it is) and I can't stand it. it's really heavy and really doesn't grab all that great. but maybe it's still the stocker in there and its slipping and my cable is just rubbing somewhere and thats why its stiff. i'm not 100% sure...
Threads Similar to: Clutch
Clutch I need a clutch guru nHuman General Tech 2 September 22nd, 2009 05:12 PM
Clutch Or Clutch Cable OR Shifter??? 96GtGoodz 96-98 21 July 27th, 2009 02:59 AM
clutch replacement- replace whole clutch assembly or just clutch disc? WilltheThrill 4V / SVT 12 December 13th, 2008 12:18 AM
CLUTCH AND CLUTCH CABLE MAJOR PROBLEMS Hububula 5.0 Mustangs 3 May 28th, 2007 10:08 AM
Getting My Clutch Quadrant, Adjustable Clutch Cable and 97Cobra 4V / SVT 3 May 2nd, 2007 02:33 PM
