95 Cobra valve spring specs??
Old February 13th, 2009, 10:26 AM   #1
1995svtcobra's Avatar
95 SVT Cobra
1995svtcobra is on a distinguished road
I have a 95 cobra that I'm having a valve job done on. The initial problem was that one of the vavle springs broke cyl #6 on the intake side. So I took everything apart and now my heads are at a machine shop. The guy is having a hard time finding a factory valve springs. He's asking me for a cam spec sheet which I don't have. The car is a stock cobra, no one has been in the motor, so it should all be stock. Do any of you know the stock specs on the factory vavle springs for this car? I think he said he needs height (maybe open and install height) and the open pressure in lbs. I called ford, they can no longer get the springs, and have no info on the specs. I then called summit, they have some aftermarket eldelbrock springs the specs on those are 1.77 install height, 120 seat pressure, .2 open height, 1.44 O.D. of spring, 338 lb open pressure. The tech guy said these were for a mild cam, but would work for a stock bottom end set up. Any help would be great, the guy has had my head for a month, I'm ready to get my freakin car back together.
70 mm Eldelbrock MAFS,K&N,King Cobra Clutch,EGR Delete,Off road H Pipe,BBK chrome shortys,Dynomax Mufflers
Old February 15th, 2009, 06:06 PM   #2
Racinjason81 is on a distinguished road
look into the trickflow spring upgrade from summitracing.com for stock 5.0 heads they are supposed to be good to a .542 lift cam.the extra pressure would be great if you plan on adding boost
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old February 16th, 2009, 09:02 PM   #3
95 SVT Cobra
i'll check it out thanks for the response
Old February 16th, 2009, 09:18 PM   #4
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
yeah seeing as you're getting a valve job done, you might as well get yourself some new springs. I'm really pissed that I didn't do that... the trickflow springs are an awesome upgrade. +1 on those!
Threads Similar to: 95 Cobra valve spring specs??
Valve Spring Kit?? BoostHard1210 99-04 11 February 12th, 2009 09:19 AM
valve spring upgrade? V6Power 99-04 3 December 7th, 2008 04:11 PM
Valve Spring Troublee! tehdwarvenn 5.0 Mustangs 12 September 12th, 2008 07:20 AM
Valve spring cups hooligan 2.3 Mustangs 0 March 31st, 2008 11:57 AM
Valve Spring removal acmillr 99-04 0 January 7th, 2007 09:53 AM
