94 Mustang GT
economical 351w build
i have a 351w that i am going to build. i have tf upper with tw heads. so, i am going to use the cam, heads, upper intake, cai throttle body and msd ignition system. i am also going to use the same crank from the 351w. what do i need and for the best price?
which TWs do you have 170s,185s or 205s.the 170s are a little on the small side but shouldnt be bad as long as you dont make it a stroker.Im not sure if you are gonna find a lower intake to match your upper unless its an r series.Eagle SIR i beam rods would be
great for 500hp(they handle more HP than they are rated to)and are very light also,the rods are under 300bucks press pin or bushed.you also should get a set of forged pistons speed pro has a set for 335 bucks(trw-L2446f30) both the rods and pistons are available from Summitracing.com
as for parts to swap a 351 in a 302 car you will need a 351 oil pump,351 oil pump shaft,351 oil pan,351 28oz flywheel/flexplate,351 28oz dampener,P/S bracket,351 headers,351 TFI distributor.you could get a summit SFI dampener for 150bucks,melling standard volume oil pump for 29bucks,ARP oil pump shaft for 20bucks,as for the oil pan,o/p pickup,dipstick and shorty headers could be had for 359bucks from holcombmotorsports.com.you also shouldnt waste your time with an MSD distributor since the stock 351 distributor is more than adequate and a lot cheaper you can use one from a early 90s E or F series with TFI 351.
1995 Mustang GT
1995 Mustang GT
sorry, I couldn't help it...
on the more serious side, +1 to everything racinjason81 has said.
Threads Similar to: economical 351w build
| 351w fox efi and turbo build tips | 5.8mustang | 5.0 Mustangs | 9 | October 22nd, 2008 12:22 PM |
| 351w build help question | suzuki827 | 5.0 Mustangs | 3 | September 14th, 2008 11:03 AM |
| Finalization Help Of 351w Build (Impatient Readers Beware) | teal89 | 5.0 Mustangs | 11 | May 26th, 2008 05:24 PM |
| I Changed My Build To A 351w! | JONJON | 5.0 Mustangs | 7 | December 4th, 2007 11:24 PM |
| Build on a budget-351W | KJeezy | 5.0 Mustangs | 8 | September 8th, 2006 01:12 PM |
