Looking to Help Out A Friend w/ A 5.0
Old February 21st, 2009, 09:43 PM   #1
Semper Fi
beefmobile's Avatar
2006 Killer
beefmobile is a jewel in the roughbeefmobile is a jewel in the roughbeefmobile is a jewel in the rough
Ok i've got a buddy that has a 95 5.0, that he has an ungodly amount of bolts ons for. However, his 1/4 time doesnt show as much as it could. I would like to see him get some lower E/Ts...maybe it's a tuning problem?
Here's what i know of that he has:
Cam
BBK T/B
Edlebrock intake manifold
shorty headers
O/R X pipe
Triax S/T
Intake
U/D pullies
NITROUS
3.73 Gears
New Block (at some point--pretty sure it's same displacement)
315 Tires
1/4: between 14.5 and 15.5
Maybe he has one or two bolt ons more than i mentioned but that's all i know for sure. Any suggestions? All help appreciated, Thx guys.
USMC CREW
NCMM ORIGINAL CREW
You would think they used camm'd LS1's to launch space shuttles.
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
(Must be 18, void where prohibited, not available in all states, restrictions apply)
Good Night Chesty, Wherever You Are
Old February 21st, 2009, 10:50 PM   #2
Moderator
casper gt's Avatar
2012 300a gt auto
12.10@116
casper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant futurecasper gt has a brilliant future
need a lot more info than that to get started but something doesn't sound right given the basic mods/times.
MM BRACKET RACING CREW CO-FOUNDER
BAMA Performance Drag Team Founder
2012 300a GT auto
Old February 21st, 2009, 10:56 PM   #3
marlow331's Avatar
1995 Mustang GT
marlow331 is on a distinguished road
can he drive the thing? driver mod and traction make a hell of a difference
1995 GT - 331, Exhaust, Suspension, Built AODE, 3000 Stall, Nitrous, 4.10s, 03/04 Cobra 31 Spline Diff and some Mosers
2000 Grand Prix GTP - 3800 Eaton Supercharged, Stock Daily Driver.
Old February 21st, 2009, 11:03 PM   #4
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
he is probably blowing the tires out through third gear...especially if he's spraying... tell him to get some SEAT TIME, D/R's, Control Arms, Subframes, etc.
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old February 22nd, 2009, 07:16 AM   #5
onequicktang is on a distinguished road
something is not right. Its probably the tires, he should be able to run better than that with just nitrous.
Old February 22nd, 2009, 07:19 AM   #6
mylilboostedpony's Avatar
2001 Mustang GT
mylilboostedpony will become famous soon enough
Send a message via AIM to mylilboostedpony Send a message via MSN to mylilboostedpony
is the No2 like a 75 shot???
id say things but i dont know much about 5.0's and someone would jump all over me
Отряд милиции особого назначения
White Mustang Crew Co-Founder
Old February 22nd, 2009, 08:06 AM   #7
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
i'm gonna guess with the others that it's a traction problem... is it an AODE or a t5 tranny?
if he is launching on spray, i guarantee he's spinning all first, probably most of second, and maybe chirping third since he's got 3.73's.
The best things he could do would be to:
-replace his Rear Lower Control Arms with an aftermarket set (MM or Steeda)
-Replace his Upper Control Arm bushings (keep the stock arms)
-If he's got 315 tires, he probably took his quad shocks off... put those back on and get some wheel spacers (quad shocks will prevent any wheel hop - they will help to stop axle bind up)
-Weld in subframe connectors
-Some drag radial tires
-and LEARN HOW TO F'N DRIVE!
with those mods he should be in the 13's, and depending on how much he's spraying, it should be LOW 13's... Maybe you could help your buddy out and give him some advice for how to get himself down the track... hope this helps!
Will
Old February 22nd, 2009, 08:21 AM   #8
Semper Fi
beefmobile's Avatar
2006 Killer
Alright, i just remembered from you guys mentioning it that he has welded subframe connectors. And the tires are either 305s or 315s, so i'm not sure about those quad shock thingies.
he's got a 75 shot i believe, WOT, sprayed from the intake.
Also, please note that he does absolutely NO work to his car. he drives it down to a shop in florida and has the 'do it up'. well, i think they may be doing him up on the bill and not the work.
Problem is, we switched cars once cuz i thought he just sucked at driving. Granted, it was my first time in a 5.0 in about 3 yrs (had a 94 ) and also my first time in his car, and also my first time running spray.
i ran a 15.8!!!! lol but the thing is, i know his car HAS to be faster. This is why i think it might be a tuning problem. He tells me, without spray, it put out around 220rwhp and around 280ish on spray....that doesnt make sense??
also, to support you guys thinking he needs the driver mod, not sure cuz we only did one pass in each others cars and i don't usually get to see him run cuz i'm in line too. the pass before that, i ran a 13.0 in my car, and he ran a 14.9 just seconds after me, but also, it was his first time in an s197, so it's expected.
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old February 22nd, 2009, 10:10 AM   #9
WildWill's Avatar
1995 Mustang GT
do you know what cam he's running? if you seriously think its an issue with the car, then there could be a lot of problems... stock injectors/fuel pump could be failing, a/f might be way off, the cam might be hurting it more than helping it (without a tune), he should probably be seeing more than 220rwhp with those mods, so somethings probably up. you could try taking it to a well known tuner in your area and have him run it on a dyno and work it out. or, you guys just suck azz at driving his car.
Old February 22nd, 2009, 02:29 PM   #10
Ryno8705's Avatar
Ryno8705 is on a distinguished road
What heads is he running? All the intake goodies you mentioned he has will only flow as much as the largest bottle neck, which is the heads. If he has stock E7 heads and a large cam, he could actually lose horsepower and torque for most of the power-band. What's his fuel pressure with the vacuum line off?
Old February 23rd, 2009, 08:37 PM   #11
Semper Fi
beefmobile's Avatar
2006 Killer
He has stock heads (to his knowledge)
IMO, if i were him i would change the plugs, new fuel pump/injectors, run that C foam or whatever thru it, put in some good oil, clean the air filter, get a GOOD tune on it and i think he should see better results.
Also, he says there's a problem with his shifter. he says it's a Triax, and when i drove it, it feels like youre shoving a stick in a bucket of Lego's....
USMC CREW
NCMM ORIGINAL CREW
ΜΟΛΩΝ ΛΑΒΕ
Bill of Rights
Old February 23rd, 2009, 09:04 PM   #12
M L Struck's Avatar
85 GT/86 SVO/2010 GT500
M L Struck will become famous soon enough
Get a time slip give us th R/T,60ft,660,1000, trap speed that will tell you some of the problems. my 94 gt with tires and 125 hp spray ran like 13.6 first pass
Old February 24th, 2009, 02:19 PM   #13
WildWill's Avatar
1995 Mustang GT
+1 on what Ryno said. Beefmobile, I would suggest what you just did (do a regular tune up) to him and then see where it goes.
Old February 24th, 2009, 03:15 PM   #14
delgadog's Avatar
1997 Mustang GT
None yet...
delgadog is on a distinguished road
hey guys, i'm beefmobile's buddy with the 5.0, i have another thread on here that says track problems, check it out. i have some of my time slips, i just can't remember what they say, i really appreciate what beefy is doin. it proly is a driver mod, i just go out there and have fun, but i'd like to see some nice times too. only reason i don't do my own work (i can, i just choose not to) it is my daily driver and if i screw something up and the car explodes ima cry.... lol so i take it to Blow By Racing and they've done most of the tuning and wrench time for me.
95 GT - nothing stock on her R.I.P.
97 GT - New hotness: CAI, 70mm TB, TB Plennum, PI Intake
comming soon: PI H/C, shorty headers, o/r x, lower car, sub frames, cc plates, torque box kit, rear U/L control arms, NO2 kit 100 shot.
Threads Similar to: Looking to Help Out A Friend w/ A 5.0
need help for a friend jasons_98gt 96-98 6 February 3rd, 2009 05:36 PM
who wants to be my friend??? SWEET2KSTANG The Clubhouse 9 August 23rd, 2008 02:14 AM
got a new friend WilltheThrill The Clubhouse 13 July 14th, 2008 12:20 PM
something a friend sent me WilltheThrill The Clubhouse 23 July 10th, 2008 04:26 PM
my new best friend WLJohnson05 The Clubhouse 2 May 18th, 2008 03:26 AM
