2000 mustang GT
how do you know when ones EGR is bad?
i think thats the problem ive been having for a while, some days it feels great and then it out of nowhere it gets all boogy and takes for ever for the RPM's to rise and i feels a mojor power loss. so what you guys think
KB'd GT
Not sure. The egr is off at idle and wot. Can you describe the symptoms better? Typically with too much egr you will feel it at part throttle as kind of a shuffle.
2000 mustang GT
symptoms are:
slow acceleration popping sounds from exhaust(connected to slow accel) engine feels like has a lot of resistance or load when giving it gas |
KB'd GT
Maybe the cats are clogged? Is it slow acceleration at WOT?
2000 mustang GT
yeah some times it feels like that.
1994 GT
is the popping almost like a can with some metal pieces rattling in it? cause it souns like uve def. got some clogged cats
Cohagan Engineering, Inc. |
2000 mustang GT
dam, so what do i do about this other than replacing the mid pipe?
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
well man seems like we're in the same boat....i'm having all the same problems you are it seems.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
2000 mustang GT
its a sad day indeed
. so what causes this to happen?
1995 Mustang GT
i wish i knew i'm leaning towards the egr in mine as well, i posted another post in the 5.0 section a few mins ago, about my problems, i've replaced pretty the whole fuel system and ignition system. and still the same symptoms but at wide open throttle it runs fine most of the time. but at crusing speeds it will sputter at random. no particular rpm seems to set it off. Just at random, yet it can be sputtering the whole time and i can push the clutch in and it'll rev up fine. Sometimes i have a problem with it starting i'll have to sometimes hold the throttle just a lil bit for about 15 seconds when i 1st start in in the morning or the car will die sometimes, The motor shakes at idle. sometimes so bad that the car is shaking. as far as that popping noise it doesn't happen very often at all but occasionally when its sputtering if you give it full throttle to even it out sometimes you can hear it pop...does that sound simlilar to your issue??
95 Mustang GT
take the cats off and see if the problem goes away. Check the laws in your state if the inspection for emissions is visual then take them off and hollow them and put them back on. I used to have a long extension for a air ratchet that I welded some blades (kinda like arrowheads) and I could hollow them out in just a few seconds.
![]() People should think about boarding up their glass house before starting a rock fight! |
#12 | ||
2000 mustang GT
yeah thats how mine is.
95 Mustang GT
yeah as long as you dont have emissions testing, and if you do just swap it back and forth, keep the old one with cats for when you have to get checked
2000 mustang GT
ive been looking into them and i see i have three choices, o/r H,X and a prochamber. whats the diff between these?
Threads Similar to: how do you know when ones EGR is bad?
| EGR VS EGR delete? | riggsracin | 94-95 | 5 | December 14th, 2008 11:56 AM |
| EGR | all5.0motor | 94-95 | 9 | October 23rd, 2008 01:39 PM |
| bad egr - 1/4 mile | Rustbelt | 5.0 Mustangs | 15 | May 17th, 2008 09:02 AM |
| IAC BAD??? OR throttle body bad? | Rico-mofos | 99-04 | 10 | March 12th, 2008 06:32 PM |
| Bad Bad Bad situation | mustangmanic | The Clubhouse | 32 | October 26th, 2007 10:55 PM |
