cam comparison with my combo
Old February 27th, 2009, 01:56 PM   #1
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
Hi all,
My combo is in my sig... GT40p heads, GT40 explorer upper/lower, 1.7 roller rockers, and a few other goodies. Nothing has been ported. I'm considering a cam... After some research I think I want the Steeda #19, but my question is whether it would really be worth it???
Would I see significant improvements with the Steeda 19 with 1.7's over the stock GT cam with 1.7's with my GT40p heads??? I know that sometimes if you put a cam in these cars and you don't have the heads to support it then it will actually hurt your performance... Obviously, I don't want to go backwards. So let me know (as far as hp/tq numbers go) what you think the Steeda 19 would add to my combo. I was originally wanting to do an AFM b-21 cam, but I've decided I don't want to go that radical, so the Steeda is the best choice for me I think. If anyone has another suggestion please let me know. Thanks in advance,
Will
Old March 1st, 2009, 06:14 PM   #2
Racinjason81 is on a distinguished road
the B-cam and the Steeda 19 have both around the same specs.If the steeda has a wider lobe seperation than get that one since it would give you better driveability.I dont think Iron GT-40s move air above .500in.An E cam is hit or miss with a SN95 and could cause driveability problems.the b or 19 cam with 1.7s would give you around .510 lift.you would be better off with 1.6rockers since their are not many cams with lift under
.500 in of lift.
Heres a real funny video
youtube.com/watch?v=ojB7KkaR03I
VTEC stands for Very Torqueless Economy Car
Honda stands for Hold On Not Done Accelerating
1991 LX 5.0 H/B(T-70 turbo coming soon)
Old March 1st, 2009, 08:34 PM   #3
Sleeper_Stang_89's Avatar
1989 Mustang Gt
Run me and find out!!!
Sleeper_Stang_89 will become famous soon enough
how about an AFM or Comp Cams XE cam?
331 ways to WASTE an LS1...
I love pink
Originally Posted by sgrcltpunk View Post
dont fuck with bad pussy
Old March 1st, 2009, 09:56 PM   #4
WildWill's Avatar
1995 Mustang GT
I don't want a letter cam... I was looking at the Steeda #19, the Anderson B-21, and I haven't looked at anything else yet... Comp?
Can someone verify that my GT40P heads wont push air past a .500 lift cam? I want to keep my 1.7 rr's cuz I don't want to have to buy another set. Say I get a cam that has more lift than the air my heads can move, will that hurt my performance rather than help it?
I should also mention that I'm planning on nitrous in the future... Probably 125/150 shot. So what's a good cam for the spray??
Old March 1st, 2009, 10:26 PM   #5
86er's Avatar
if you want a cam for spray get as much duration split as you can to help the nitrous work.
example a 224/228 cam wont work as well as a 224/236 split cam
Just a truck
Old March 1st, 2009, 11:26 PM   #6
That a bold statement to make.....
You custom grind cams.....???
What are the ramp rates and valve timing on each of those cams?????
PeteAndersonRacing.com
Old March 3rd, 2009, 08:24 AM   #7
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Originally Posted by WildWill View Post
Hi all,
Not really. I estimate you have about 280rwhp/325rwtq now and with the Steeda 19, you'll gain some HP but lose some torque. If you're going to change cams at all, I suggest you go for either the CompCams XE270HR-12 or the Anderson B-31. Both will produce almost identical results with more torque across the board than the stock cam and an estimated 290rwhp/330rwtq. Not a big difference so you'll need to decide if the cost is worth it.
Incidentally, both of the cams I mentioned have a longer exhaust duration which will help with a nitrous set-up, and the 112* LSA should keep valve overlap and idle quality at a manageable level.
243.5rwhp/284.2rwtq
Mod list in My Garage
Threads Similar to: cam comparison with my combo
Cam comparison M L Struck 5.0 Mustangs 20 December 13th, 2008 11:35 AM
Choosing A Cam For My Combo? Darrellx14 5.0 Mustangs 9 December 23rd, 2007 11:37 PM
Engine Combo? Cam Selection? datsundave3 94-95 3 December 10th, 2007 10:05 AM
More 3.27, 3.73, 4.10 comparison w/99-01 GT w/T-45 TheBusher 99-04 3 August 7th, 2007 04:15 PM
new combo!!! best cam??? luizGT91 5.0 Mustangs 5 April 13th, 2007 10:46 PM
