1994 Mustang GT
rear suspension questions
does any know or has any1 every done a 03 rear irs swap n2 a 94 mustang? since they are both sn95 bodies would it be that difficult?
94 cobra
i'm pretty sure you can but i have to ask why ?
cobra R hood (has a vin#) bassani catback flows welded in jegs O/R H-pipe Jlt CAI Mgw shifter 03 cobra rims 3.73's (on the way!!!) |
2000 mustang GT
+1 the solid axles are stronger.
1995 Mustang GT
yes you can do it. if you are looking at doing road racing it's an excellent idea to do the swap.
1994 Mustang GT
yeah the reason is to make a better road race car! i am thinking since they r both sn-95s it shouldnt be much of a problem just wanted to see if any1 has done it b4
94 cobra
i think there might be a write up or corral not 100% on that tho
Yes it's possible and it has been done. Good for road racing but the IRS adds about 75lb of extra weight. That's why the 03 Cobra has a weight distribution closer to 50/50 than any other SN95 Stang.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1994 GT
u know u can make a solid axle a road race car jus as easy..there was a huge dilemma on here about it a while bac..but solid axles can handle jus as good
Cohagan Engineering, Inc. |
1995 Mustang GT
^^ that may be true, but as Bullitt said, handling is all about weight distribution and it is really hard to get an sn95 close to 50/50 front/rear weight balance. usually about the closest you can get them is 54/46... and IRS definitely helps with that weight distribution problem.
You could just keep the solid axle and stick a large sack of cement in the trunk to even up the weight distribution.
1994 Mustang GT
thanx for the info guyz i will check on corral for that write up thanx again
Threads Similar to: rear suspension questions
| Steeda Suspension- Suspension Questions | MustangJon255 | 2005 - 2010 | 22 | June 2nd, 2010 05:43 PM |
| Suspension Questions | OhhShorty | 99-04 | 5 | January 18th, 2009 11:52 PM |
| suspension questions | 03 R Code | 4V / SVT | 11 | December 17th, 2008 07:36 AM |
| Suspension Questions!! | bubsdelicious | 5.0 Mustangs | 0 | September 5th, 2008 12:10 AM |
| suspension questions | mustangsoldier | 5.0 Mustangs | 8 | August 7th, 2008 09:46 PM |
