HELP 212 Code + vacuum
LinkBack (1) Thread Tools
Old March 11th, 2009, 12:48 AM   1 links from elsewhere to this Post. Click to view. #1
RubySlow is on a distinguished road
The problem is I had my Passenger front tire blow and it ripped some vacuum lines off the engine, also Throwing a code 212 (Ignition module circuit failure/SPOUT circuit grounded.) <- I will have to check the wires...
Okay my tire I think rip off some of this hose
I think this goes to AIRB solenoid. underneath the passenger fender, I see a solenoid hanging with a sensor
takin from a diagram
l
"Connector C-176 (female) Secondary Air Injection Bypass (AIRB) Solenoid
(2) terminals
Located high on the inner splash panel on driver's side in front of the Mustang's passenger side strut tower.
Connector plugs directly onto the solenoid, so no modifications are required (wiring details shown for referance only)
Ckt190 white/orange
Ckt361 red "
Okay So Im not worried about that cause I could just run the car without the AIRB or AIRD (basically Smog/egr delete without removing anything)
The car won't Idle. I was thinking it was the vacuum hoses. But the 212 code, and a 10 code which is #1 cylinder maybe its the computer not reading the Ignition or Crank sensor so TDC cant be found or cant determine timing because of ground or short from spout connector/ IDM
any input is greatly appreciated
Old March 11th, 2009, 01:50 AM   #2
My problem is I had my Passenger front tire blow and it ripped some vacuum lines off the engine, also Throwing a code 212 (Ignition module circuit failure/SPOUT circuit grounded.) <- I will have to check the wires...
Anyways I see you have moved or rerouted your vacuum lines.
l
(2) terminals
Ckt190 white/orange
Ckt361 red "
1995 Mustang GT 5 Speed
100,000 miles, Cobra Intake, Custom cold air, 73mm MAF, 24# injectors, Cobra R tranny, B&M Ripper Shifter, Strut Tower brace, Intrax Springs, 3:55 gears, Aluminum Driveshaft. MSD 6AL Ignition, MSD Distributor, MSD 8mm Wires.
Old March 14th, 2009, 10:22 AM   #3
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Fix all the vacum lines and check the wires to the spout connector. If they are grounding then the pcm is getting false readings for the timing.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/114403-help-212-code-vacuum.html
Vacuum Line Diagram 1995 Mustang - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback March 31st, 2010 07:49 PM
Threads Similar to: HELP 212 Code + vacuum
Vacuum Qs hmargov1 Classic Mustangs 3 February 14th, 2009 06:05 PM
Intake vacuum help dr.gonzo! 5.0 Mustangs 29 September 21st, 2008 05:33 AM
vacuum leak? Nev3rL1ft89 5.0 Mustangs 1 January 4th, 2008 05:52 PM
vacuum... sivart 5.0 Mustangs 22 July 31st, 2007 11:02 PM
Intake/vacuum FiveOOH89 5.0 Mustangs 3 July 28th, 2007 06:19 AM
