Discussing NEED ADVICE: especially if someone has stroked and engine in the 94-95 Forum. The main seals on my engine are going I will have to replace them. This ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
The main seals on my engine are going I will have to replace them. This garage quoted me $1,500-2,000, well after hearing that i decided to do it myself. I am probably going to pull the engine for convenience, and I was wondering if this would be a great time to stroke my 351 to a 408. From what I know stroking it just involves changing the crank, rods, rings, and I will probably leave the pistons. Anybody know how long of a job that will be? I am only home for a few weeks before I get stationed in Germany. Some links would be great. Thanks.
#2 | |
Re: NEED ADVICE: especially if someone has stroked and engin
http://i179.photobucket.com/albums/w...llcardcopy.jpg |
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
not necessarily
GTConcept05: i'm dying of cancer here,, please jack me off for me ^^ ![]() slow car club - crew member 1 of 9 join www.moddedautos.com i had my bowl of WIN for breakfast. did you? |
i have seen a lot of kits that come with pistons, but i have keith black pistons and don't want to change them out
Usually when you stroke an engine you have to increase the stroke of the piston and you also increase the bore of the cylinder. If you want to keep your pistons then you will have to get a new crank and shorter rods. I dont know what kind of horsepower that will buy you. Also I dont know if it is different of 351s but when you stroke a 302 you have to clearence the block for the increased stroke of the crank.
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
You will have to change the pistons if you stroke it because of the change in stroke and rod length. The pin where the rod connects to the piston is moved up in the piston. If you wanted to do a low budget stroker you could use a 351W and buy a set of 302 pistons and a 3.85 stroke crank. You can then use the stock 351W rods and it will make 393 cubic inches with a 4.030 bore.
Racing in memory of Dave Bandt 11/19/69 - 3/23/08 "he's traded his wheels for wings" Professor of Natural Aspiration ![]() Thanks to: Artie at Trick Flow, Dave at Team Z Motorsports, Brian at Total Engine Airflow and Harold at Furo Racecraft |
would it be smarter to go 393 or 408? what would the HP gain be compared to the 351, and the HP gain between the difference of 393 compared to 408.
Feb 08 ROTM
1990 Mustang LX
9.36@143 mph
Bigger is better. Going to a 408 just costs a bit more.
do you have any idea what the HP gain would be going from 351-408? I think I might want to supercharge it after that but am not sure, should i set the compression higher? or make it around 8.5? Running that much HP, what sort of other things am i going to need to upgrade in order to handle the horse? i know i will need bigger injectors, maybe tranny?
Threads Similar to: NEED ADVICE: especially if someone has stroked and engine
| Need Advice (Engine Knocking) | DeathScythe95 | V6 Mustangs | 37 | November 14th, 2007 10:31 PM |
| Need Engine Build Advice Please | coony278 | 5.0 Mustangs | 17 | November 14th, 2007 12:35 AM |
| New Member...need advice on new engine | lil2v4.6 | 99-04 | 17 | July 2nd, 2007 10:10 PM |
| pulling engine need advice. | hawaiiankine | 5.0 Mustangs | 10 | March 5th, 2007 12:34 AM |
| engine swap? i need some advice | cobrakid | 5.0 Mustangs | 7 | January 17th, 2007 08:52 PM |
