Power steering pump or pulley squeak
My power steering pump or pulley is chirping / squeaking.
1994 5.0 After spraying some silicone spray where the pulley meets the shaft, it will stop for a few minutes. Question: Since the pulley is pressed on, does it have bearings, or are the bearings in the pump itself? I am 100% sure it is either the power steering pulley or the pump! I am not sure which one to replace, or both.
1995 Mustang GT
the bearings are in the pump itself if i'm remembering correctly so you'll need to replace the whole pump. you can reuse the pulley.
94 cobra
aka deal with the sqeaking for now
cobra R hood (has a vin#) bassani catback flows welded in jegs O/R H-pipe Jlt CAI Mgw shifter 03 cobra rims 3.73's (on the way!!!) |
Look Ma! My First Post!
i seem to have the same problem with my upper pulley any chance is can get it out or i have to change the whole thing any i ideas .
95 Mustang GT & 03 Cobra
If it gets worse you might wanna replace it, mine locked up and left me stranded on the highway since its a single belt system and made the belt stop the crank. I know O'reilly's has em for about $100 and it only takes twenty minutes tops to switch the pumps out
Threads Similar to: Power steering pump or pulley squeak
| Power steering pulley search | bossman69 | Classic Mustangs | 4 | November 4th, 2010 09:55 AM |
| 67 power steering pump | lord7 | Classic Mustangs | 1 | September 25th, 2008 11:36 PM |
| power steering pulley | vxpena | V6 Mustangs | 2 | July 12th, 2007 02:56 PM |
| power steering pulley | 94stallion | V6 Mustangs | 6 | May 9th, 2007 04:19 PM |
| Decreasing power steering pump pressure for tighter steering | 83 5.0 | 5.0 Mustangs | 6 | January 7th, 2007 09:24 PM |
