#21 | ||
Shit can get pretty complicated, but this should help you get an understanding. That lifting is the tires getting pushed into the ground. Last edited by engineer1229; April 13th, 2009 at 05:45 PM. |
#22 |
1995 Mustang GT
I need to read that again when I'm not so dog tired... but thank you for that explanation. I'll get back to you tomorrow with my thoughts... It makes a lot of sense tho...
#23 |
And there are slight variations on what works for different suspension systems, 4 links, torque arms, leaf springs etc. But the basic concepts, instant center, center of gravity, pinion angle, can be applied to all of them.
#24 |
1995 Mustang GT
So what I take from this is that the optimum set up would be for the rear suspension to neither "lift" or "squat." You want it to remain stationary as the weight of the car is transferred to the rear wheels on takeoff. I understand that as the rear lifts, it acts to "plant" the rear axle and the tires to the ground. That makes sense. I'm not trying to make an argument, but wouldn't the springs compressing ultimately do the same thing? As they compress, they store the kinetic energy needed to decompress themselves in return - as the force of decomression acts against that of compression, wouldn't that as well as the combined weight of the car plant the rear axle to the ground in the same way?
I'm not an engineer (as I would guess you are... lol), so if you can put that concept into the perspective I just looked at, can you try and clarify that for me?
#25 |
89mustanglx5.0
It was a while ago, but I think I remember I had a friend whos stang would lift slightly up on all four corners when he got on it, while cruising... but I think it was normal. He had subframe connectors and stuff done to it. a 3.73 rear gear too. was a nice stang.
![]() thought Id add- his was a 92 I think. fox body.
looking for a mustang again.! Last edited by 89Domindart; April 14th, 2009 at 02:12 PM. |
#26 | |
Its wasted energy compressing the springs when that force could be pressing down on the tires. A slower car might not even run any different if it set up on complete opposite sides of the spectrum (one side being it raises and the other squatting) but if your going max effort with something its all the little things that will put you ahead at the finish line. Yeah, yeah def not an arguement. I just wanted to help clear up the confusion so next time you see the car lift, or the car squat, you might know what causes it and a little bit on how to adjust for it. I'm not an engineer yet, I've still got a couple years of HELL left.
#27 |
I Poop Entirely Way Too Much
Blown 03 GT
I just read that info on this "anti-squat", while its all tru, like the info it self says that is all ideal condition. Most of the guys on here have stangs running slightly modded suspension not race set ups. Ill admit I dont know much about suspension but I do know engineering. Also theres a reason you always see drag cars squating. When a car squats it transfers weight to the rear wheels to help with traction. If the rear is lifting and your suspension isnt designed for that you MAY be losing some traction. Very little in the world of engineering works as it does in theory.
#28 |
1995 Mustang GT
SLOWER THAN OLD PEOPLE FUCK..:-(
alot of lowered cars are gonna "raise the rear end" its not actually lifting the rear end up like alot of you are taking it to mean....while the car normally would squat from transferring weight when its lowered the suspension is gonna be alot more stiff, so when torque is applied to the springs in the back the suspension is pushing back hard from being more stiff, thus making the body appear to lift up, its just the suspension pushing hard thats all.
![]() 1995 Mustang GT..4.30's,BBK Longtubes, Off Road X-Pipe,Magnaflow Catback,BBK Intake,BBK Underdrive Pulleys Walbro 255lph pump,accel dizzy,MSD Coil,MSD 8.5 Super Conductors,front sway bar removed, more coming soon. |
#29 | |
It came from here. Downloads - Race Glides Australia Last edited by engineer1229; April 15th, 2009 at 09:28 AM. |
#30 | |
As the axle and ds both spin it will try to rotate the axle out from under the car. The different angles will all affect this. This rotation causes the force, if large enough it lifts the cars ass end up, if its small enough it will be over taken by the weight transfer and squat the car. Springs and shocks are a related but thats not what they do. Springs can make the car lift up in the rear when they rebound, but when a spring rebounds it won't stay extended. When it comes back down it will unload the tires. Shocks smooth this motion out. |
Threads Similar to: so i lowered my car this weekend...
| h-pipe on lowered car | boatn70 | 99-04 | 4 | April 28th, 2008 10:34 PM |
| Car is lowered! | dmachine22 | 99-04 | 12 | February 14th, 2008 05:48 AM |
| got the car lowered | 00redgt | General Tech | 2 | November 29th, 2007 06:40 PM |
| Lowered the car. | ricks01 | Multimedia | 33 | September 17th, 2007 10:37 AM |
| Car lowered | Nameless122 | V6 Mustangs | 29 | July 26th, 2007 01:30 PM |
