1994 Mustang GT
need help please!! fuel problem
ok i just installed a 255 lph fuel pump but the car still has the stock injectors and maf and now when i get to about 3000 rpm it cuts out and starts to sputter like its not getting enough fuel any advice or info to y this is would be greatly appreciated thanx
1994 GT 5.0, 302 c.i. studded and girdle, Cobra upper and lower, gt40p heads, 3.73 gears and stock T-5, boostbrothers turbo kit, master-power t70 turbo, pro-m mass air, 80# injectors, manual rack, tubular k-member, a-arms, upper & lower control arms |
How did it run before you changed the fuel pump?
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1994 Mustang GT
it ran fine with the 95 lph pump but i couldn't get into boost
I don't get it. You said you couldn't get into boost. Is your engine supercharged 'cause it doesn't say so in your sig?
Sounds like your new fuel pump isn't working properly. You might wanna have it tested to see if it really IS flowing anything like 255lph (4.25L/min). |
i would do a little more research on the fuel pump upgrade.my goal would be to make sure my fuel pump requires or doesnt require other components in the fuel system to be upgraded as well. this way i can bypass any performance issues.
#6 | |
100% Genuine Walbro Fuel Pumps Last edited by 2002BLGT; October 9th, 2009 at 04:44 PM. |
1992 Lx
11.39@119.24
nope 255lph pump works fine with the stock fpr and everything else
1994 Mustang Gt
Soon to come
His sig says that he has a boostbrothers turbo.
"Train hard, kill everyone, ask questions later"...94Gt,Trickflow 170's,Trackheat upper/lower, custom cam. In need of suspension work. |
1994 Ford Mustang GT
^ lol at least someone seen it, well not making boost could be a combo of a bunch of different things, as far as the fuel pump/combo should be fine, id get it tuned and find out what your real issue is
www.moddedmustangs.com |
Threads Similar to: need help please!! fuel problem
| 98 GT Fuel Problem | stevo629 | Modular Mustangs | 4 | October 9th, 2009 12:31 PM |
| Fuel Problem | JerseyTrueBlue | 99-04 | 9 | March 23rd, 2009 10:28 AM |
| Fuel Problem | tehdwarvenn | 5.0 Mustangs | 5 | December 15th, 2007 10:18 PM |
| fuel problem????? | haywood11 | 5.0 Mustangs | 5 | August 17th, 2007 10:30 PM |
| have a fuel problem help!!!!!!! | tag team | 5.0 Mustangs | 11 | November 30th, 2006 10:30 PM |
