Help with fuel injectors
Hey everybody I am still having issues with my car not re-starting after it runs for like 5 minutes or more. It will usually start in flood mode though. What I noticed was when I took readings on my Fuel injectors I noticed 9 volts on injectors 7 and 8 with the key in the third position(Engine not running)
. All the other injectors had a reading of 0 volts which is what I expected. Correct me if I am wrong but the computer only sends 12 volts to the injectors at the proper time in which they should fire...... I'm guessing my computer is messed up and is keeping those two injectors open all the time and this is allowing those two cylinders to flood. Let me know what you all think.
1995 Mustang GT
Your assumption makes sense to me... I don't know what would cause the computer to be messing that up tho. Perhaps those two are just bad injectors. You could try replacing them?? I know that's an expensive thing to "try" but maybe it would be a good excuse for an upgrade
Well when I tested for voltage I had the connector unplugged from the injector. I just wanted to see if the computer was sending voltage to any of the injectors at the wrong time. It seems that 7&8 are being told to fire all the time. The CCRM supplies 12 volts to the accessories and the computer grounds the injectors to complete the circuit. I'm going to test my CCRM tomorrow and if all the pins show the right voltage values and proper ground then I am going to assume the computer is whacked out. Any other suggestions keep em coming.
Update
CCRM pins all checked out ok. Pulled off my harness in the engine bay leading down to the EEC in the kick panel and probed the two pins for injectors 7 & 8 and they showed 1.6 volts. This tells me the problem is from that point to the computer itself. I checked to see if I had continuity with all the other pins and there was no continuity present, not even with ground. At this point I feel it's got to be the computer. Let me know what you all think.
Ok, here goes I had 12 volts to all the injectors with the key in the third position. The side that gets grounded by the EEC had 1.6 volts on it for injectors 7 & 8. I probed with my DMM and found the problem to be on the computer side of the harness. Checked for continuity between the wires for 7 & 8 and all the other wires in the harness. The check came up negative which meant there were no shorts in my wiring. Swapped EEC's and the voltage(1.6 volts on grounded side) on those two wires went away and the car starts up each and everytime with no hesitation. The car also pulls alot harder all the way through to redline. As of right now the oil consumption has been reduced as well. Thanks for all you alls help ok.
Diagnose and then repair FTW!
Glad to see you did that instead of replacing parts until you fixed the problem.
Threads Similar to: Help with fuel injectors
| SVT fuel pump, fuel injectors | Kennhyy3 | V6 Mustangs | 2 | December 19th, 2008 06:08 AM |
| Fuel Injectors/fuel pressure | 00silvergt | 99-04 | 4 | August 2nd, 2007 10:54 AM |
| Fuel Injectors | Euroeater95 | 94-95 | 5 | June 21st, 2007 12:02 PM |
| Fuel injectors | ssdell3 | 99-04 | 36 | June 20th, 2007 11:56 PM |
| Fuel Injectors | camer | V6 Mustangs | 3 | November 15th, 2006 07:05 PM |
