Tune needed after cylinder head install??? - Page 2
Old June 4th, 2009, 12:00 PM   #21
delgadog's Avatar
1997 Mustang GT
None yet...
delgadog is on a distinguished road
yea, it was a package, i got upgraded springs with roller rockers from crane, i got a 5 angle job, the works.
95 GT - nothing stock on her R.I.P.
97 GT - New hotness: CAI, 70mm TB, TB Plennum, PI Intake
comming soon: PI H/C, shorty headers, o/r x, lower car, sub frames, cc plates, torque box kit, rear U/L control arms, NO2 kit 100 shot.
Old June 4th, 2009, 12:23 PM   #22
delgadog's Avatar
1997 Mustang GT
None yet...
i got a 5 angle job, upgraded springs from crane with roller rockers resurface job and port and polish job. the shop i went to was highly recomended in the area as a pretty good engine builder.
Old June 4th, 2009, 12:38 PM   #23
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
It doesn't matter how recomended the shop is, $1100 in a set of GT40P heads is a waste. You could have bought a good set of heads for that price. I guess it doesn't matter, you are stuck with them now and if all of the work was done properly you can rule the heads out as your problem. If the problem started after swapping heads then you need to look at everything involved with the swap. Vacuum leaks, wiring, rocker adjustment, etc.
Old June 4th, 2009, 02:04 PM   #24
delgadog's Avatar
1997 Mustang GT
None yet...
yea, thats why i'm going to get it dyno tuned as well as get a basic tune up. see if that would fix the problem. yea, i know i could've gotten a nice set of patriot heads, but oh well. i guess i learned a valuable lesson. i got a flow chart with the heads, and with
.500 lift it flows 214cfm, i know i could prolly get more out of patriots or similar head.
Old June 4th, 2009, 02:32 PM   #25
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Patriot heads would have been a bad choice. $1100 would have got you a nice set of used Twisted Wedge heads and rockers. 214 @ .500 isn't much more than what P heads flow stock. What are the numbers at .300 and .400? those numbers are more important than peak numbers.
Check for vacuum leaks and scan for codes. It could be a real simple problem.
Old June 4th, 2009, 03:31 PM   #26
delgadog's Avatar
1997 Mustang GT
None yet...
no codes thankfully, might be a vacume leak, but i'll check out all possibilies. i'm not sure what it flowed at .300 and .400, i think in the 160's and 180's.
Threads Similar to: Tune needed after cylinder head install???
All parts needed for swapping cylinder heads. unlicensed to drive 2005 - 2010 10 March 19th, 2009 09:00 PM
cylinder head work viperlocc 5.0 Mustangs 3 February 1st, 2009 02:50 PM
5.0 need a tune after head and intake install? kid 5.0 Mustangs 17 April 23rd, 2008 01:02 AM
Cylinder Head Question burin_rubber V6 Mustangs 8 April 10th, 2008 08:41 PM
Just finished Head and Cam install, do i need a new tune? MySallyMI 99-04 22 February 28th, 2007 08:34 PM
