gear clatter?
Old May 31st, 2009, 06:06 PM   #1
1994 mustang gt
94vortech is on a distinguished road
gear clatter?
i havent really heard of this before but thats what my mechanic thinks is going on in my car. Its like a constant grinding noise that is most noticable in 4th (at high rpms) and 5th gear. He also said he didnt think it was fixable unless i did a whole new tranny. I also heard this is typical in highly modified cars with after market transmission. Can anyone give me a further explanation or have any other suggestions.
thanks
Old May 31st, 2009, 07:07 PM   #2
Lind's Avatar
1994 Ford Mustang GT
Lind is on a distinguished road
never heard that before, i know once in a very great while mine might pop out of 5th depending how i shift into it, and slaming the gears 2nd to 3rd grinds alittle sometimes
edit: do you have a short throw shifter or anything like that? if so how long have you had it in there? and has it started grinding since you intsalled it, if so might be a bad install causing your issues
www.moddedmustangs.com
Old May 31st, 2009, 09:13 PM   #3
1994 mustang gt
Ya i have a short throw shifter in it. I bough the car in the winter and never put it into 5th gear because of the weather and when i took it out from the garage this spring and took it on the highway i noticed the noise.
Old June 1st, 2009, 12:20 AM   #4
95BlackStang's Avatar
2000 mustang GT
95BlackStang will become famous soon enough
thanks
it could be your throw out bearing, does your clutch feel different when you hear the noise?
00 GT with the heart of a green machine!
99 Electric Green GT R.I.P.
95 GT vert....my first love sold!
Originally Posted by BaznastyDave View Post
99-01 Cobra bumper with Mach spoiler and make all the girls panties wet.
Old June 2nd, 2009, 12:30 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
thanks
Its a bad bearing. He is right, the transmission has to come out. It can be fixed, you don't need a new transmission. But the part about it being typical in modified cars with aftermarket transmissions is wrong.
Threads Similar to: gear clatter?
Rocker Clatter? acobraman 4V / SVT 20 November 26th, 2008 07:34 AM
Gear to gear on a Mach stangless24 4V / SVT 25 June 11th, 2008 07:24 PM
Cam gear and camshaft position sensor gear... 99v6stang V6 Mustangs 17 January 17th, 2008 03:00 PM
Does anyone use gear to gear timing? e3sean 5.0 Mustangs 24 December 27th, 2007 03:37 PM
4.30 Gear to much gear for street use/daily driver? Bigb2000GT 99-04 10 March 28th, 2007 06:22 PM
