351w intake manifolds
Old June 2nd, 2009, 12:09 PM   #1
1995 mustang
rlpiii is on a distinguished road
Hey, im new to this forum site but i could use all the input i can get. ive got a 95 rollin chassis and Im building it for strictly the strip. Ive already got a 351w block bored 60 over and i want to use that block and build it from top to bottom. im also goin carbed instead of efi. with all of that said, does anyone had any ideas on what intake manifold to run. im goin to need somthin that will still alow me to rev past 8 grand.
Old June 2nd, 2009, 12:24 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You need to be concerned about more than just the intake for that rpm. What heads are you using on this engine? What about camshaft and valvetrain?
Old June 2nd, 2009, 12:31 PM   #3
1995 mustang
as far as heads go im looking at running a set of dss racing heads. not sure which ones yet though. not sure about the cam or valvetrain. any suggetstions?
Old June 2nd, 2009, 12:38 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
DSS doesn't make heads. You need to figure out what your goal is for the car and how much money you have to spend. Why do you want to spin 8000+ rpm? Is this a dedicated race car? How fast do you want to run with the car?
Old June 2nd, 2009, 12:46 PM   #5
1995 mustang
this is a dedicated race car. i want the car in the mid to low sixes in the 8th mile to start with. when i said dss heads i meant that i was gonna order a set of air flow research heads from dss. dont know if i should get the 185cc or the 205cc. As far as money goes its really not a factor. im goin to take as long as i need to build the car right the first time.
Old June 2nd, 2009, 01:12 PM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
What size engine do you plan on running? I wouldn't use AFR heads.
Old June 2nd, 2009, 01:20 PM   #7
1995 mustang
ive already got a 351w block bored 60 over. its already got a steel crank and eagle i beam rods in it. what heads to you recommend i should run? i need something thats going to be able to handle up to a 200 shot of nos.
Old June 2nd, 2009, 02:08 PM   #8
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
You don't need to turn anywhere near 8000 rpm to run mid 6s in the 1/8 with 200hp of nitrous. Do yourself a favor follow this link Camshaft Innovations - SBF195
Get the Canfields and a CI cam. Mid 6s will not be hard with nitrous.
Old June 2nd, 2009, 02:14 PM   #9
1995 mustang
i appreciate it... ive got another question for ya. ive got an 8.8 rear end out of an older coupe with thats already been regeared with .410 and it has strange 28 spline axels. i know the rear end is shorter than the 8.8 out of the 95 but i was told it would hook harder than the stock 8.8. is this true and would it still bolt up to the suspension on the car?
Old June 2nd, 2009, 03:16 PM   #10
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
That rear end is going to do nothing for you. Those 28 spline axles will not last in a car that runs low to mid 6s in the 1/8. It isn't going to hook any harder because its shorter. It will bolt in but it isn't going to work for what you are doing.
Old June 2nd, 2009, 03:52 PM   #11
1995 mustang
thats what i thought. guess im just gonna upgrade the stock rearend with new gears and 31 spline axles
Threads Similar to: 351w intake manifolds
Intake manifolds Jakashh 99-04 6 January 14th, 2009 01:36 PM
Intake manifolds??? mayday 99-04 3 September 25th, 2007 01:11 AM
Intake manifolds? DCstangGT 99-04 20 September 9th, 2007 03:47 PM
After Market 351W EFI Intake Manifolds 5.0newbee 5.0 Mustangs 4 April 19th, 2007 11:54 PM
intake manifolds............ ERIC 99-04 1 January 21st, 2007 12:54 PM
