1995 mustang
new cam for a 351w
looking at putting a big mutha thumper cam in my 351w block bored 60 over. its a .552 intake lift with a .538 exhaust lift. its rpm range is 2,500 to 6,200. is this cam suiteable for a dedicated drag car looking to run in the low sixes in the 8th mile spraying no more than a 200hp shot of nitrous?
#2 | |
1995 mustang
well i was lookin at running that cam, a set of rhs heads and comp camps magnum pushrods and lifters and rocker arms. that would complete my top end with products manufactured by one company.
Making sure you buy your parts from one company is not going to make you fast. I'd be looking at a solid roller as well, not a hydraulic roller. A posted a link in your other thread that gives you the information parts that will make you the horsepower you need for your goals. You can take that advice and make some horsepower or you can just throw a bunch of parts together and hope for the best....
Chassis set up is going to be another topic of discussion. The car is much more important than the horsepower.
1995 mustang
what chasis mods would you recomend? as far as the rear end goes im goin to use the stock 8.8 rear end with superior 31 spline 5 lug axles and 4.10 ford racing gears
#6 | |
Superior 31 spline axles are not a wise choice for a 9 second 1/4 mile car (which is what you will have with a low 6 second 1/8 mile). You are going to need a 33-35 spline axle from a good company like Strange, Mark Williams or Moser.
1995 mustang
alright. i looked at ordering a jegster 10 point roll cage. is that a good roll cage?
A roll cage is only as good as the person that installs it.
Threads Similar to: new cam for a 351w
| Cam installation - Comp cam stage II | Dolbs4082 | 99-04 | 4 | February 28th, 2009 10:36 PM |
| 302 cam with 351w question | viperlocc | 5.0 Mustangs | 3 | November 1st, 2008 03:27 PM |
| 289 cam vs 351 cam | Kenn | Classic Mustangs | 11 | May 5th, 2008 01:20 PM |
| E cam or F cam horsepower and 1/4 mile time questions | GreyGhost | 5.0 Mustangs | 1 | August 21st, 2006 06:25 PM |
