13.7@103
What type of intake should I get?
So one day i was driving and a fricken Cobalt SS beat me by just a little bit. Money is a issue for me as im still going to school. so im deciding on a upper/lower intake. anyone got any advice? Edelbrock? Trickflow? So far the only mods i have on my car are some headers, catback, CAI, ignition coil. And im also looking around for a x-pipe.
The Cobalt SS is very quick (14.0sec 1/4 mile) so don't feel bad. With a few choice mods you can turn the tables and annihilate the same vehicle. Just decide what your goal is and then we'll help you select the right parts to get you there.
Do you want strong torque from idle-5500rpm or do you want it higher up the rev range and spin to 6000+rpm? Is your Stang going to be seeing mainly street use or will it be visiting the track a lot? Is your tranny manual or automatic?
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1995 Mustang GT
first answer Bullitt's questions...
but I would recommend the Eddy RPM II over anything else.
95 opalfrost gt
Put the intake on hold and get a set of gears instead. You will get more from the gear swap than from the intake swap at this point.
94 cobra
i get a holley systemax
cobra R hood (has a vin#) bassani catback flows welded in jegs O/R H-pipe Jlt CAI Mgw shifter 03 cobra rims 3.73's (on the way!!!) |
The Razor's Edge
i say gears too....
The Razor's Edge
or the TF Track heat
13.7@103
My car is a manual and it is mostley street use but i need to take the highway to get to work. my goal in this car is around 350 at the flywheel. I don't want to supercharge or cam my engine. as i have a 04 gt after school that i want to do that to after. (2 years left)
13.7@103
I kind of want a Edelbrock, but am not sure how much power it will put up.
1995 Mustang GT
You wont be anywhere near 350 hp with the stock GT cam and no blower. You're gonna have to pick one.
If that's your hp goal, then you should seriously look into the trick flow top end kit. That will put you right there and its a very well proven kit.
13.7@103
How much do you think that'll cost? and what all in the kit?
2000 mustang GT
like around 2k for the kit, here ya go 87-93 ENGINE KIT, TOP END - STREET HEAT WITH BLACK POWDERCOAT MUSTANG, and you will need an intake elbow 94-95 THROTTLE BODY ADAPTER, 5.0L/5.8L 75MM THROTTLE OPENING - BLACK POWDERCOATED MUSTANG. with that you should be were you want to be.
#13 | |
Then you can do heads/cam/intake as others have suggested. Any one out of the Trick Flow, Edelbrock, and Holley top end kits will get you at or above 350 flywheel HP (Trick Flow more like 360-370). You could also consider the AFR 165 heads, Edelbrock Performer RPM II intake, and the CompCams XE270HR-14 cam. The latter would be a killer combo.
13.7@103
Now im really interested in the trick flow kit. Im gonna really try and save up this summer and get the kit, mid-pipe, and gears. Thanks guys.
The Razor's Edge
with the money you spend on that kit...you can build a better set up....have you considered a stroker?
1995 Mustang GT
^^^^ now you're just gonna start confusing the poor guy
the kit is a great way to go if you're just starting into the modding world because it includes everything you need to do the swap. all you have to do is just pull it out of the box and go. there's no doubt what you said is absolutely right, White Thunder, but for his purposes I think the kit would be a good way to go. and if the trick flow kit is right at the edge of his budget, there's no way he's going to have the $$ for a stroker. so Mike, just do right and save your money and in the mean time, do some research on different kits and what all is required to do the swap. Maybe you'll find something better. Good luck!
13.7@103
Thanks guys, yeah i don't want to go to far with this car as my dream car is a affordable 04 gt, and this is my first car and first time modding and i love it. thanks everyone.
13.7@103
Alright guys so its summer now. i just put together a catless x-pipe sounds amazing! I also picked up another job at a autobody shop. working lots now. i think i can get the kit and the gears by the end of summer! It will be a killer machine! will i have to have any other mods to handle this power?
1994 Ford Mustang GT
fuel pump and injectors wouldnt hurt
www.moddedmustangs.com |
13.7@103
How much do they usually run for? and can I do without them?
Threads Similar to: What type of intake should I get?
| TL type s | ZoomZoomMFer | 96-98 | 6 | March 25th, 2008 10:10 PM |
| What Type of Cam Should I Go With? | neestangk | 94-95 | 5 | August 1st, 2007 10:54 AM |
| type of intake? | Midnight Stang02 | V6 Mustangs | 9 | May 8th, 2007 08:57 AM |
| this is my type of woman | 232stang | The Clubhouse | 24 | April 25th, 2007 07:37 PM |
