good set of pistons and rods??
Old June 18th, 2009, 11:06 AM   #1
joedaddy4's Avatar
1994 Mustang GT
joedaddy4 is on a distinguished road
i'm looking for some expertise on what kind of pistons and rods that would be good for my car i recently turboed it and didnt change anything in the bottom end so i'm looking for it to throw a rod or something soon i've already blown thehead gaskets in it and just replaced them but i have another motor on the side to build so when it does go any advice would be great thanx
1994 GT 5.0, 302 c.i. studded and girdle, Cobra upper and lower, gt40p heads, 3.73 gears and stock T-5, boostbrothers turbo kit, master-power t70 turbo, pro-m mass air, 80# injectors, manual rack, tubular k-member, a-arms, upper & lower control arms
Old June 18th, 2009, 12:04 PM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Stock. The block is weaker than the crank, rods and pistons. I'm suspecting you aren't running much boost anyway, otherwise you wouldn't be using the stock block. You better get that tune in check though or you will melt your engine down, no matter what pistons you are using. You shouldn't be blowing head gaskets. Something is wrong.
Old June 18th, 2009, 12:10 PM   #3
rodeheavers's Avatar
1981 4 EYED FREAK
9.48@147
rodeheavers is on a distinguished road
probe, manley, srp, ross, weisco, there are tons of good pistons out there.. but you should think about a block upgrade if you wanna get into the 500+ hp range..
www.rodeheavershotrod.com
9.48@147 on pump gas through the
mufflers, still has pw,tilt,t-tops,all
lights, wipers!!!, check out the vid
http://www.youtube.com/watch?v=SloE3Zdetac
Old June 22nd, 2009, 09:51 AM   #4
joedaddy4's Avatar
1994 Mustang GT
thanx for the advise
thanx fro ur input but dont really have the money to throw at a good block right now,maybe future. but i was thinking along the lines of what type of piston: dished, domed, or what? and rod type h-beam or i-beam? thanx for any advice
Old June 22nd, 2009, 09:51 AM   #5
joedaddy4's Avatar
1994 Mustang GT
thanx for ur input but dont really have the money to throw at a good block right now,maybe future. but i was thinking along the lines of what type of piston: dished, domed, or what? and rod type h-beam or i-beam? thanx for any advice
Old June 22nd, 2009, 10:00 AM   #6
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Keep the stock pistons and rods. There is no reason for you to upgrade them. The stock pistons and rods will outlast the stock block. If you decide to turn the boost up down the road then it will be time for an aftermarket block and a good rotating assembly. Until then, keep what you have and get your tune in check. Blowing head gaskets is a sure sign that something is wrong so you should address that issue soon.
Old June 23rd, 2009, 04:29 AM   #7
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
The stock rotating assembly is fine up to 6500rpm so you can keep that. The block is also good up to about 480-500rwhp and you definitely won't have more than that with your set-up.
You could be blowing head gaskets either because the block deck/head surfaces are not perfectly flat or because the engine's detonating (too lean or too much timing).
243.5rwhp/284.2rwtq
Mod list in My Garage
Old June 23rd, 2009, 01:17 PM   #8
joedaddy4's Avatar
1994 Mustang GT
i believe the problem with the head gaskets were that i running lean because until recently i had the stock pump, injectors, and mass air meter(i know) but i just had to have that turbo kit installed, itwas only til after i put my 42lb injectors in and a bigger pump and mass air. the day i installed those items not even an hour later i get on it and it comes alive and when i hit third my radiator pops meaning all that pressure busted the head gasket and pressuized the radiator till it popped, thought i slung a rod at first then was able to smell radiator fluid thankfully.but thanx for the info and yes i am very new to the whole boost thing and somewhat new to engine building this is my first time ever replacing head gaskets. don't laugh too much
Old June 23rd, 2009, 01:34 PM   #9
94 cobra
96gtponyred is on a distinguished road
what other mods do you have done to your car besides you sig and what turbo kit are you runnin
cobra R hood (has a vin#)
bassani catback flows welded in
jegs O/R H-pipe
Jlt CAI
Mgw shifter
03 cobra rims
3.73's (on the way!!!)
Old June 23rd, 2009, 01:34 PM   #10
Bullitt95's Avatar
13.546 @ 105.32
Old June 23rd, 2009, 03:18 PM   #11
joedaddy4's Avatar
1994 Mustang GT
thats pretty much it just the stock block, cobra upper and lower, pullies and the boost bros turbo kit with t67 runnin about 7 lbs. of boost and the stock t-5 third tranny by the way all free so can't complain i only have about $2500 in the car total thats the car included
Threads Similar to: good set of pistons and rods??
pistons/rods.....??? silverstang 4V / SVT 9 November 26th, 2008 01:15 AM
pistons and rods 4.6 94stang 99-04 26 February 19th, 2008 06:46 PM
pistons rods Bhblondguy 2005 - 2010 11 November 7th, 2007 05:46 PM
Pistons Rods Bhblondguy 2005 - 2010 3 November 7th, 2007 01:50 PM
Pistons Rods Bhblondguy 2005 - 2010 0 November 5th, 2007 10:08 PM
