95 GT turning off while driving
My GT turns off every now and then feels like its because of the transmission, is it possible?
I'll be driving and all of a sudden the my rpm's will drop all the way and turn off or sometimes they will jump back up. Please help........ |
95 opalfrost gt
Possible bad ground
bad distributor/distributor cap.
maybe the tfi module....i know they were the common culprit on fox bodies for that problem.
Go Tarheel's, your our men, if you can't do it!!!............................................. ...............................DAMN!!?? |
any other ideas?????
did you check out the distributor and cap cuz i had a probe that did the same thing and thats what it was, and it could possible be an alternator but i would lean more toward distributor.
my car used to stutter and shut off sometimes...i believe it was one of the wires on the harness...it is fine now tho
1995 GT::Sold! Looking for another stang... |
95 opalfrost gt
Have you checked all your ground wires? Esspecially the one to the coil.
sounds like the IAC (idle air control valve)
1995 Mustang GT GONE BUT NOT FORGOTTEN EST.300-320RWHP 86 Notch Project 10's or Bust |
Check your battery terminals too, I've had that problem, is your battery tied down?
#11 | |
what do i look for? |
with the distributor cap, just take the cap off and look for corrosion on the inside. Mine had visible built up corrosion. or you can always do what i do when i dont know whats wrong, take it to a local shop, have them diagnose it, and fix it yourself. usually they charge around 100 dollars depending on what they find
#13 | |
Threads Similar to: 95 GT turning off while driving
| Having trouble turning over? | ricerraper33 | V6 Mustangs | 14 | November 11th, 2007 01:36 AM |
| Turning Signals!?! WTF! | Nameless | 2005 - 2010 | 3 | July 22nd, 2007 04:12 PM |
| tsb 05-14-3 help...squeek when turning help | KhaosGT | 99-04 | 8 | July 19th, 2007 05:57 PM |
| Mach 460 not turning on | emptysouls0 | Audio/Video | 2 | February 24th, 2007 12:39 AM |
| intervention?...I am turning myself in | innrkid | Pictures | 10 | January 27th, 2007 04:17 PM |
