still can't figure it out... can anyone help??
Old June 25th, 2009, 04:07 PM   #1
delgadog's Avatar
1997 Mustang GT
None yet...
delgadog is on a distinguished road
i just installed gt40-p heads about 2-3 weeks ago. only after the heads were installed i started experiancing back fires and some hesitation in the car. when i get on the gas it starts to sputter and i can't stand it! i did some research and i read i have to retard the timing to reduce detonation... i was kinda hoping to find out what everyone with a similar set up as me has for timing??? i have a 306 with stock MAF and injectors and the last time i remember the timing was advanced. also, i keep hearing some metal clanking around in one of the cylinder heads, a mechanic told me it could be the lifters... i have stock springs and push rods with 1.7 roller rockers, is there a possibility that i have bad lifters and the timing needs to be retarded due to the higher compression??? and is retarding the timing something i might be able to do in my drive way with the proper tools??? or should i just go somewhere to get the timing retarded??? i'm racking my brain as to what it could be... also, vaccume lines are good. thank you for your help!!!
95 GT - nothing stock on her R.I.P.
97 GT - New hotness: CAI, 70mm TB, TB Plennum, PI Intake
comming soon: PI H/C, shorty headers, o/r x, lower car, sub frames, cc plates, torque box kit, rear U/L control arms, NO2 kit 100 shot.
Old June 26th, 2009, 06:42 PM   #2
WildWill's Avatar
1995 Mustang GT
WildWill is on a distinguished road
when i first put my heads on I had this exact same issue. as it turned out my timing was waayyyy off!!!! I guarantee that you didn't put your dizzy back in correctly when you put everything back together. check your base timing. you do not need to retard your timing at all with your new heads, I actually advanced mine.
also... check your sparkplug wires. did you get 90 degree boots to go with your "p" specific headers? if not, then I can also pretty much guarantee you that you have burned up at least one plug wire and you are most likely only running on 6 or 7 cylinders. I made this mistake at first too.
clanking in your heads is a bad thing. try and get your timing right and check your plug wires before you do anything else... then update us and we will see where to go from there.
Old June 26th, 2009, 06:43 PM   #3
WildWill's Avatar
1995 Mustang GT
oh and just so you know, I'm running base timing at 14* with zero problems.
Old June 26th, 2009, 09:20 PM   #4
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Like I said in your last thread, "Did you have the heads milled at all? If not then you haven't changed the compression ratio because the chamber size is the same as the original E7 heads.
When did the backfire and hesitation problems start? After the swap? Is the distributor phased correctly? What is the timing set at and was it set correctly? Did you check for vacuum leaks? Double check and make sure everything is connected properly. Scan for codes".
You also said in a previous post "new springs, which by the way were to stiff for my hydrolic cam". Until you put the correct parts together you are going to have nothing but problems and broken parts.
Old June 28th, 2009, 11:36 AM   #5
delgadog's Avatar
1997 Mustang GT
None yet...
ok, i'll check the dizzy and put the timing to 14* as a base line. yes, i have new plugs with the 90* boots with heat wraps so they don't get burnt up. i checked and rechecked for vaccume leaks, and nothing. i did port and polishing to these heads. when the mechanic put the springs i bought he said that the cam couldn't push up the rockers, so i had the new springs out with my stockers. the back fire only started after the head swap. so i don't get it...
Threads Similar to: still can't figure it out... can anyone help??
cant figure it out... ZoomZoomMFer 99-04 19 May 29th, 2009 04:24 PM
No one else can figure this out, but I know you can! jkellam 94-95 7 October 8th, 2008 11:36 PM
cant seem to figure this out 91foxhatch5.0 5.0 Mustangs 3 February 8th, 2008 07:32 PM
cant figure it out notsoslow50 5.0 Mustangs 7 July 12th, 2007 09:25 PM
cant figure it out ttop5.0 5.0 Mustangs 2 August 26th, 2006 06:54 PM
