1994 Mustang Gt
Soon to come
Surges
So, my car has been getting bad gas milage, not sure if its cause of running ac more, or what. Also it has been surging and running rough at idle. No codes been trown recently, just replaced plugs and air cleaner. You guys have any suggestions?? Oh and should I be able to feel heat coming up though my consol after driving around for a while.
"Train hard, kill everyone, ask questions later"...94Gt,Trickflow 170's,Trackheat upper/lower, custom cam. In need of suspension work. |
1997 Mustang GT
335rwhp/370rwtq
IAC for idle surging
1994 Mustang Gt
Soon to come
Ok, its not huge, but sometimes I can tell and occassionally itll even shut off, especially in reverse, or maybe i just suck at driving ha
1997 Mustang GT
335rwhp/370rwtq
lol i would need more detailed info for a proper diagnosis attempt
1994 Mustang Gt
Soon to come
Okay lets see, it flashed codes earlier this year, but it stopped eventually. Well i ran ac a few times and my gas milage droped from 18-20 to 15-17. Also the idle surges just a tad when sitting at a stop sign, and it likes to die on me in reverse sometimes. But it suns fairly well. Ive only had it a few months. Could it need o2 sensors??
^Agreed, try taking it off and cleaning it with some carb cleaner and cuetips or somthing. I did it to my old car and the surge stopped. Also might wana clean MAF while your under the hood.
Go Pokes! MM Cobra Club #33 VERT CREW #02 |
15-17 is average for these cars...you were lucky to see 18-20. IAC should be your first check about the idle.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1994 Ford Mustang GT
well with your ac on your car is going to lug alittle at the stop sign but only for a few seconds and then when the compressor kicks in it should tell the car to jump the idle up to 1100 to 1300 rpms
it shouldnt be dieing in reverse unless you arent giving it gas lol, as soon as i let the clutch out in reverse i dont ever have to touch the gas again, just the brake for the most part lol
www.moddedmustangs.com |
1994 Mustang Gt
Soon to come
Thanks guys. I'll check the IAC ive cleaned the maf once now, but hey why not do it again ha
1995 Mustang GT
mine doesn't idle very well with the a/c on as well... as stated, the idle is supposed to jump up when the compressor kicks on... is this not happening a result of a bad or dirty IAC? what senses that the compressor is on?
2000 mustang GT
the ccrm is what control the ac circuit.
Threads Similar to: Surges
| 20 ft. Storm Surges... | Dansby | The Clubhouse | 56 | September 13th, 2008 08:09 PM |
| 99 stang surges when put in gear, or with ac on | dobermean | 99-04 | 7 | August 16th, 2007 06:30 PM |
| 94 ford mustang surges at idle and cuts out when push gas | akahoops | 5.0 Mustangs | 5 | February 18th, 2007 02:31 PM |
| Engine surges at start and idle fluctuates | 200KMILES | V6 Mustangs | 2 | May 3rd, 2006 05:23 PM |
