1994 Mustang GT
Need Help bad!!
ok so i replaced the head gaskets and got everything back together and now i have more blow-by than before and what sounds like a slight backfiring noise when just sitting at idle it only backfires i say like every min or so of idle and when i give it a little throttle and let off it does it too it just sounds like a kid with a cough just does it randomly its turbo charged too by the way any advise would be great
1994 GT 5.0, 302 c.i. studded and girdle, Cobra upper and lower, gt40p heads, 3.73 gears and stock T-5, boostbrothers turbo kit, master-power t70 turbo, pro-m mass air, 80# injectors, manual rack, tubular k-member, a-arms, upper & lower control arms |
does your oil look like a milkshake?
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1994 Mustang GT
no its nice and clear thats what i was thinking at first but i drained the oil when i blew the head gasket
Are you sure the ignition timing is correct? Sounds to me that it might be off.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
are you sure its coming from you head gaskets and not your intake?
1994 Mustang GT
Well Im Thinking It Might Be The Timing But I Didn't Ever Remove The Distributor And The Blow-by Is Coming Out Of The Dipstick Tube It Actually Pushes Oil Out Of The Dipstick Tube
WOW...it definately shouldnt do that...you need to re-pull your heads and check all the exhaust and intake ports etc. how long were the heads off the car? sounds like their may be an obstruction somewhere...i cant see timing making oil come out the dip stick hole.
In that case you have a far more serious issue than timing. Before you pull the heads off again, you might wanna check that the PCV valve isn't stuck closed and that the mesh screen inside the lower intake is clear.
1994 Mustang GT
the heads were off the car for about 2 weeks they were not warped, valves look ok besides being white in color i guess i was running too rich and i did take out that little mesh screen in the lower intake and attempted to clean so maybe i just clogged it up more but when i start the car and i did rev it up to about 5000 rpm the oil will litteraly shoot out the dipstick tube PCV VALVE WAS NOT STUCK OPEN
1994 GT 5.0, 302 c.i. studded and girdle, Cobra upper and lower, gt40p heads, 3.73 gears and stock T-5, boostbrothers turbo kit, master-power t70 turbo, pro-m mass air, 80# injectors, manual rack, tubular k-member, a-arms, upper & lower control arms Last edited by joedaddy4; July 10th, 2009 at 11:38 AM. |
1994 Mustang GT
sry caps lock was on but thanx for all options and advice
u got to repull the heads and check everything..u never know what could have happened...dirtdobber, kids toy etc...something is way wrong...sucks man..hate it for you..
1994 Mustang GT
thanx i will try that though hopefully i find something i do have three kids soo u never know lol also, do u think it might be in the valvetrain area? would a bent valve cause that? and could the piston rings let that much blowby through? again thanx for all the advice
Threads Similar to: Need Help bad!!
| Bad...Gators...Bad | oldernewbie | The Clubhouse | 3 | November 15th, 2008 04:58 PM |
| IAC BAD??? OR throttle body bad? | Rico-mofos | 99-04 | 10 | March 12th, 2008 06:32 PM |
| Bad Bad Bad situation | mustangmanic | The Clubhouse | 32 | October 26th, 2007 10:55 PM |
| bad bad wreck | 232stang | The Clubhouse | 12 | April 8th, 2007 12:37 PM |
