Car just shuts off!!! - Page 2
LinkBack (2) Thread Tools
Old November 24th, 2009, 09:58 PM   #21
dsmith is on a distinguished road
Iwas scared to drive mine also. However good as new now.
Old November 30th, 2009, 06:17 PM   #22
DejaBlue87's Avatar
95 gt
DejaBlue87 is on a distinguished road
Originally Posted by 95project View Post
i have a stock dizzy from a 95 with rotor and cap for sale. FYI
how much? im gettin ready to put a 351 in mine so i dont want to buy a performance distrib for it. but i want to at least b able to drive the car again lol
Old January 18th, 2010, 01:00 AM   #23
1995 Mustang GT
Mikestang95 is on a distinguished road
I have a 95 mustang gt and i have trouble with it alot it shuts off. i replaced the dis,cap,rotar,ignmodule,igncoil and it still shut off and when i try to check the car it says error on it and dont know what else to do does anyone have any suggestions?
Old January 18th, 2010, 03:26 AM   #24
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Sounds like you also have a PIP sensor problem Mike. If you still have the original 15-year-old distributor, I suggest you just replace the whole thing rather than just the PIP sensor. Chances are you'll need to replace it sooner or later anyway 'cause the distributor shaft bearings will inevitably wear out, leaving a lot of play in the shaft that can break rotor tips (ask me howI know!).
243.5rwhp/284.2rwtq
Mod list in My Garage
Old January 18th, 2010, 03:38 AM   #25
castine917's Avatar
95gt,67maro,05sti....
14.8@93,13.6@101,
castine917 is on a distinguished road
mine must be a later 95 cause autozone can hook up and check mine just fine.
Old January 18th, 2010, 11:26 PM   #26
1995 Mustang GT
I replaced the distributor because the rotor tips kept breaking, but it still keeps shutting off.
Old January 19th, 2010, 11:17 AM   #27
Bullitt95's Avatar
13.546 @ 105.32
Your new dizzy could have a dud PIP sensor.
Old January 20th, 2010, 12:13 AM   #28
1995 Mustang GT
k thanks bro i appreciate it...
Old January 20th, 2010, 12:29 AM   #29
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
This same thing just happened to me. I recently rebuilt my engine and had to get a new dizzy. Got one from Congress auto parts and finished the car. Ran fine for a few weeks and then one night while driving on the highway it shut off and restarted on it's own. Two days later I wasn't so lucky when it again turned off while driving on the highway and I ended up having it towed home. I ended up changing and returning a bunch of sensors and even changed my computer and gave up. Next day my brother calls and tells me about all the info on the internet that points to the dizzy as the problem. But it's new I said, but screw it, tried everything else, why not and since it's under warranty. Replaced it with another new one and the car started rite up and has been running fine. Later a buddy of mine that works at Ford tells me that the remanufactured dizzy's use the cheap stuff inside and go bad. He said I should replace the pip or whatever else is in there with a new Ford unit. It's really frustrating when you buy new parts to fix a car and it still wont work only to find out later the new part was damaged from the start. This was not the first time this has happened to me.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old January 20th, 2010, 02:22 PM   #30
1995 Mustang GT
k cool thanks
Old January 30th, 2010, 08:15 PM   #31
1995 Mustang GT
okay i replaced my distributor it still shuts off and when it shuts off i get no spark does anyone know why?
Old January 31st, 2010, 09:42 PM   #32
lakefrontlivin's Avatar
1995 GT Convertible 5.0
lakefrontlivin is on a distinguished road
Send a message via ICQ to lakefrontlivin
Wow !!! Makes me want to replace my distributor now.. Just to be safe and have piece of mind. Any place that sells them for a decent price ? Maybe upgrade to something better ??? Thanx, Tom
Old February 1st, 2010, 01:05 PM   #33
Bullitt95's Avatar
13.546 @ 105.32
Get a brand new OEM Ford dizzy in that case. You won't find a better one.
243.5rwhp/284.2rwtq
Old February 1st, 2010, 07:21 PM   #34
Bullit,
What's the best place to look ? Part #..?
I think I can get it from my local dealer.. Thanx, Tom
Old February 2nd, 2010, 08:31 AM   #35
Bullitt95's Avatar
13.546 @ 105.32
That's the best place to look except in my case, none of the Ford dealers in the UAE had one so I went for a Summit Racing billet aluminium dizzy instead.
243.5rwhp/284.2rwtq
Old February 2nd, 2010, 09:55 AM   #36
Zip Your my Hero....
fastback lover's Avatar
1988 Mustang LX
N/A
fastback lover will become famous soon enough
Wow who would have thought that a little tiny piece could create so much problems.
Old February 15th, 2010, 04:44 PM   #37
trajedy is on a distinguished road
I had the same problem. I replaced my ignition control module and it runs like a charm, aside from the things I have to fix for emisisons. ICM located in passenger side of engine bay below the air box or cai (whichever you have) its mounted up in a heatsink. I believe it was either a 3/16 or 5/16 deep socket I had to use to remove the two screws.
Old February 16th, 2010, 04:21 AM   #38
Bullitt95's Avatar
13.546 @ 105.32
You said you also have a new ignition module and new coil. Check that there's no loose wiring or connections to those components. I'm scratching my head to think of anything else.
Old February 16th, 2010, 10:24 PM   #39
Last of the 302's
Road Racing Rookie
I just went through all this. Rebuilt my engine and bought new=reman dizzy from Congress auto parts. Car drove great for a week then boom, shuts off while driving on the highway. Had it towed home and replaced everything, even the computer which I didn't want to do but I was desperate. Car never turned on again. I gave up on it and was ready to send it off to a shop. My brother tells me the next day about how he's been reading up on the symptoms of the car and everything points to the dizzy? What, it's new, but I remembered it wouldn't be the first time I bought a new part and it was DOA. So went and got another one from the parts store cause it's under warranty. Car started rite up. Later I have a conversation with a friend who works at Ford and he tells me that the reman units come with cheap pip's or whatever it's called inside and they go bad easy. He told me the best thing to do would be to replace pip with a quality unit or get a new, not reman dizzy from Ford.
P.B.M.C. Member
Track Addict
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/141651-car-just-shuts-off.html
EFI Cutting out at 3500rpms - Page 2 - ClassicBroncos.com Forums This thread Refback July 19th, 2010 12:53 AM
Tfi Ignition Module 5 0 Mustang - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback November 7th, 2009 09:22 AM
Threads Similar to: Car just shuts off!!!
whenever i start my car it shuts off :((( joohnn98 96-98 8 September 6th, 2009 03:03 AM
Car shuts off..... BLK01SS 99-04 18 November 28th, 2008 09:35 PM
Smoke after car shuts off mantis3567 99-04 7 January 14th, 2008 12:51 PM
Car Shuts Off new 5.0 94-95 7 March 26th, 2007 04:10 AM
95 Gt shuts off new 5.0 94-95 0 February 25th, 2007 05:16 PM
