Coolant leaking
LinkBack (1) Thread Tools
Old October 31st, 2009, 07:47 PM   1 links from elsewhere to this Post. Click to view. #1
marq.fcb's Avatar
1995 Mustang GT
marq.fcb will become famous soon enough
Send a message via MSN to marq.fcb
Coolant leaking
A month ago I changed the antifreeze and a few days ago I noticed that the antifreeze leaking only when engine is cold.
Can anyone help me on this problem??
MUSTANG - The Car That Never Got Old Just Got New
Old November 1st, 2009, 04:47 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Where is it leaking from? You'll need to give us more information or post a photo, otherwise it's difficult to help.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old November 1st, 2009, 07:04 AM   #3
marq.fcb's Avatar
1995 Mustang GT
On the passenger side, but I can't defined exactly where, somewhere above where the discharged coolant.
I will try post a photo for a few days
Old November 9th, 2009, 09:02 PM   #4
lowp51's Avatar
1995 mustang gt
lowp51 is on a distinguished road
Send a message via AIM to lowp51
check the drain plug on the radiator. also check your hoses for any cracks, make sure they are secured to their respective points (water pump to radiator).
If only superchargers grew on tree's
Old November 13th, 2009, 04:45 PM   #5
marq.fcb's Avatar
1995 Mustang GT
Today I was at the neighbor(mechanic), and we can not accurately detect leaks from where,
but here are seen drops
leaking: turn on engine but cold
not leaking: turn off engine, or turn on engine but warm
Old November 14th, 2009, 06:16 AM   #6
Bullitt95's Avatar
13.546 @ 105.32
Sounds like the radiator core is leaking from the bottom passenger side corner. Best thing to do would be to remove the radiator, have it pressure tested at a radiator repair shop, and they can braze over the leak.
Old November 17th, 2009, 11:26 AM   #7
marq.fcb's Avatar
1995 Mustang GT
I'm not sure if the aluminum radiator can be repaired?
Thinking about buying Mishimoto radiator
Old November 18th, 2009, 06:35 AM   #8
Bullitt95's Avatar
13.546 @ 105.32
Yes it can. Aluminium has a fairly low melting point so it's easy to weld.
243.5rwhp/284.2rwtq
Old November 18th, 2009, 07:14 AM   #9
slow as sin....
pyschopath76 will become famous soon enoughpyschopath76 will become famous soon enough
its a pretty easy fix really and wont take the repair shop too long to fix, then youll be right as rain again!
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/141922-coolant-leaking.html
Coolant Leaking From Engine - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback November 2nd, 2009 06:09 PM
Threads Similar to: Coolant leaking
Help Leaking Coolant 87StangGT 5.0 Mustangs 13 November 4th, 2009 11:26 AM
leaking coolant mystery ddarkslayer 5.0 Mustangs 11 September 25th, 2009 12:12 PM
Leaking Coolant saltydog_NM 5.0 Mustangs 4 September 30th, 2008 07:38 PM
HELP!!! Coolant leaking out exhaust.... lwhitetrash88l V6 Mustangs 23 April 6th, 2007 02:40 PM
coolant leaking here i think. YNOT 5.0 Mustangs 20 March 22nd, 2007 10:18 PM
