1994 Mustang GT
Compatibility question
So, I'm in the midst of rebuilding my motor and got a couple of questions. Was thinking about a stroker, but decided against it because, hell I just can't afford it right now. But I do have a vortech charger making ~8lbs so I wanna go forged bottom. I understand the 87-93's had forged pistons, I'm wondering will all my 94 brackets bolt up to the older blocks?
Edelbrock Performer RPM heads/Intake, E303 Cam, 30lb inj's, BBK shorties to BBK off-road H, Vortech V-1, tremec trans, yada yada yada Last edited by 94bird; November 9th, 2009 at 06:53 PM. |
The block itself is the weakest part of a stock short block and the stock crank/rods/pistons will spin safely to 6500rpm, so it's a pointless exercise putting forged components inside a stock block. If you want a forged bottom end, put those components inside a stronger aftermarket block.
I think you'd be safe with a Vortech 8psi blower on a stock 302 short block as long as it's properly tuned and you don't go above 6000rpm.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
1994 Mustang GT
So that being said, I can just find a used short block from a 94-95 and should be safe?
Edelbrock Performer RPM heads/Intake, E303 Cam, 30lb inj's, BBK shorties to BBK off-road H, Vortech V-1, tremec trans, yada yada yada Last edited by 94bird; November 9th, 2009 at 06:55 PM. |
find a mexican block..cheap and stronger
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1994 Mustang GT
Gracias gents. Be back on in a few weeks when I got some money & update on how the build is going.
Edelbrock Performer RPM heads/Intake, E303 Cam, 30lb inj's, BBK shorties to BBK off-road H, Vortech V-1, tremec trans, yada yada yada |
Threads Similar to: Compatibility question
| clutch compatibility question | ndfrspd | 4V / SVT | 1 | June 14th, 2009 09:10 PM |
| clutch compatibility question | ndfrspd | 96-98 | 1 | June 14th, 2009 10:44 AM |
| X-pipe compatibility question | Jobra | 99-04 | 15 | March 3rd, 2009 07:55 PM |
| What is this value and compatibility? | INSTALLER020 | 5.0 Mustangs | 14 | September 13th, 2008 06:32 PM |
| S/C Compatibility... | G.T. Rags | 99-04 | 11 | December 15th, 2007 12:35 AM |
