turbo 5.0 vac line question
Old November 20th, 2009, 12:38 PM   #1
bretts95gt's Avatar
95 mustang gt
bretts95gt will become famous soon enough
im thinkin about puttin the vac lines on 2maro
whered did you guys connect the blowoff valve line to on the intake
and i kno i use a T fitting for the wastegate but in what vac line
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
Old November 22nd, 2009, 04:40 PM   #2
98Cobra_sleeper's Avatar
1998 mustang cobra
98Cobra_sleeper is on a distinguished road
you have to run 2 separate vacuum lines, one for the wastegate and the other for the BOV
HP twin turbo - 691hp/608tq with 15lbs huffed in (old setup)
comin soon...ON3 turbo kit, PTE7175
Old December 4th, 2009, 09:40 PM   #3
bretts95gt's Avatar
95 mustang gt
right i said that too vague the blowoff valve line runs staight to the intake on one diagram i saw for a 5.0
the wastegate went into a T fitting that was also connected to a line that was there from the factory (as in i would buy a t fitting and cut the line an hook it up that way)
im not saying thats right so if anyone has a turbo 5.0 if you could take a pic of where yours is hooked up youd be a god to me! cause i cant find a install sheet that precise for the life of me
Threads Similar to: turbo 5.0 vac line question
What is this vac line for? Hydration 5.0 Mustangs 20 November 18th, 2009 12:21 AM
turbo feed line ran from oil press. unit??? bretts95gt General Tech 9 January 20th, 2009 03:36 PM
Fuel Line Question supermachone V6 Mustangs 6 January 10th, 2008 11:42 AM
fuel line question juan310 V6 Mustangs 22 September 21st, 2007 02:32 AM
newbie off the line question..... BLK90GTVERT 5.0 Mustangs 1 May 16th, 2007 12:19 AM
