idle problems
Old January 1st, 2010, 07:57 AM   #1
94 Mustang GT
kreil45 is on a distinguished road
idle problems
i have a 94 gt with bbk cai and throttle body, trick flow street heat upper motor kit, headers, zex nitrous, sct chip (which has been tuned), pulley kit, smog delete, flow master dumps, 255lp fuel pump and 30lb injectors, 90mm maf, msd ignition and a 6al box. all this has been tuned. i can not find a vaccum leak and i have cleaned the throttle boby. what happens is that it stalls in reverse and while i am driving then engage the clutch and let off the gas the rpms stay 2000 until i come to a complete stop (i mean a complete stop) then they go down to 1100. then while it sits and idles it will jump up and down. this has been going on for a while (probable close to a year). i am ready to drive it off a cliff. someone please help me
Old January 1st, 2010, 03:54 PM   #2
hotmustang95's Avatar
Last of the 302's
Road Racing Rookie
hotmustang95 is on a distinguished road
Sounds like your TPS is bad or needs adjustment. I just recently learned about this whole deal about how the tps can be adjusted with a volt meter. We worked on a buddy's car and it had the same problem with up/down idle and turning off in reverse and he had a tech adjust it and now runs perfect. We replaced his old one cause it was broken.
Btw's I think your injectors might be too much for your setup but I'm no mechanic so maybe someone who knows for sure can chime in.
Victor ( goofyfeet) Oliver
P.B.M.C. Member
Track Addict
Old January 1st, 2010, 06:51 PM   #3
94 Mustang GT
if i replace the tps what do i set the specs at with all of the stuff that i have?
Old January 1st, 2010, 10:31 PM   #4
Last of the 302's
Road Racing Rookie
I was told for best results, under 1.00. Like .98 is ideal.
P.B.M.C. Member
Track Addict
Old January 4th, 2010, 01:02 PM   #5
94 Mustang GT
how do you adjust it with a volt meter?
Old January 5th, 2010, 12:22 AM   #6
Last of the 302's
Road Racing Rookie
I'm not sure. What I do know is you use a voltmeter to messure the current or output or whatever of the wires going into the tps and to adjust it you can actually turn the tps one way or another while messuring the volts and set it to what you want and then screw it down.
P.B.M.C. Member
Track Addict
Old January 5th, 2010, 10:25 PM   #7
mustang fanatic's Avatar
Dont Tread On Me
mustang fanatic will become famous soon enoughmustang fanatic will become famous soon enough
Send a message via AIM to mustang fanatic Send a message via Yahoo to mustang fanatic
This should help buddy /http://www.muscularmustangs.com/tps.php
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter.
Old January 5th, 2010, 10:28 PM   #8
Dont Tread On Me
This may help out also.
Detailed information about setting your throttle position sensor voltage - Ford Mustang Forums
Old January 12th, 2010, 12:24 PM   #9
1984 svo
spoolin_84svo is on a distinguished road
i think i should show you how. will make a thread cuz i havnt found one on here. yes i did use the search. im no noob to forums.
Old January 22nd, 2010, 05:20 PM   #10
94 Mustang GT
O.K. i just uplugged the tps while car was idleing and it drop realy quik then went back up. does this mean good or bad?
Old January 25th, 2010, 08:01 PM   #11
smott's Avatar
1994 GT
11.75@120
smott is on a distinguished road
sn95's are notorious for idle surge problems. i think they make some sort of IAC bypass or something that will generally fix this problem. do some research around the internet and you will find the fix, this certainly isnt an odd probblem for us 94 95's
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers...
E/T: 11.75 @ 120mph 2.0 60foot
Threads Similar to: idle problems
idle problems flattusmaximus78 5.0 Mustangs 18 March 26th, 2009 08:19 AM
Idle Problems Chasinsparks 99-04 3 December 5th, 2007 06:10 AM
Idle Problems Kosinski 96-98 5 November 14th, 2007 07:10 PM
Idle problems 98-GT 96-98 4 December 29th, 2006 11:14 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 04:11 AM
