Leaking oil cause of problem?
I was under my 94 cobra yesterday and noticed that oil is leaking from inbetween the bellhousing and engine block. Is this serious? Why is it leaking and how do I fix it? Thank you!!
2007 Mustang GT - Pretty much stock. Pypes pypebomb a/b, Tri-ax shifter. |
1991 mustang 5.0
rear main seal. the seal is cheap but you have to drop the tranny. I put in a new one a few months ago and it still leaks. not really that serious
Thats what I was thinking... I am going to have an aluminum flywheel, driveshaft and x-pipe installed. I guess Ill have them replace that seal at the time. How much do think labor would be to install all of that?
my rear main has been leaking since i bought my car 4 years ago (and probably before that too)... i've been too lazy to just fix it or have it done... i've been telling myself i'm going to rebuild the engine so i might as well wait.......
but for you, since you are already having a new flywheel ect. done it would be simple for them to change it right then & there.. i can't really tell you how much labor will be, all shops are different...
http://www.cardomain.com/ride/2461223 1994 GT: MSD 6AL, BBK O/R H-Pipe, Dynomax Race Bullet mufflers, 3:73 rear, Hurst Short Shifter, MAC cold air intake & much more coming soon! |
2001,Ford,Bullitt Mustang
If it ain't leaking to bad i guess its alright for a while but I had a buddy with the same year and his got so bad as fast as he could pour a quart of oil in it would drain right back out though it. No clue on labor
95 & 97 GT
Your rear main seal leaking will end up messing up your clutch if you don't replace it soon,that's if it's not slipping already from all the oil contaminating the clutch. Labor cost here in dallas,tx is around 300 for clutch job and add another 60 to 100 bucks for flywheel, rear seal and driveshaft since it has to come off anyway.
Threads Similar to: Leaking oil cause of problem?
| Oil Leaking | GreyWarrior07 | 99-04 | 1 | September 7th, 2009 11:56 PM |
| Leaking oil HELP !!!!!! | Nosofast | 2005 - 2010 | 14 | July 5th, 2009 11:56 PM |
| Help please leaking oil | JerseyTrueBlue | 99-04 | 7 | April 21st, 2009 06:09 PM |
| Leaking Oil | nba1341 | 5.0 Mustangs | 16 | May 12th, 2008 11:19 PM |
| Leaking Gear Oil? | Stan27 | General Tech | 8 | July 19th, 2006 11:38 PM |
