LinkBack (3) | Thread Tools |
#1
1995, gt
95 gt tune questions
hey guys. so i am thinking about tuning now...but idk what to do with my 95 gt. i know the OBD2 system started in 96, so does that mean the only way i can tune is to have a chip installed? or is there another way. i currently have a cai, 75 mm throttle body and a MAF that is not installed yet, with an o/r x-pipe and magnaflow exhaust. is a tune even worth it or should i make more minor upgrades and then do a tune that would fit all the mods? and how much would a tune for my car cost?
95 gt- 3.73 gears, cai, 75 mm throttle body, bbk o/r x-pipe, magnaflow muffler and tailpipes, steeda tri-ax shifter, 17" cobra r rims. |
9.74@142
No tune needed with bolt ons. You will be throwing money away for no gain in performance.
Make sure the car is in good running condition, run premium fuel, and advance the timing to 14* with the SPOUT connector out. Pay close attention to the car under a haevy load in high gear and at WOT. 94-95's are more prone to detonation then the earlier 5.0s, so it may not tolerate 14*. If it pings, drop it back a degree. It will run the best with 12 to 14* initial timing. Pro M used to have a performance improvement harness that allowed you to run a Fox maf PCM. The fox PCM's have more aggressive timing and fuel curves and are not as prone to detonation. But the harness is hard to find now. I'm sure someone good with wiring diagrams could do it themselfs.
i would get a tune if you are changing the MAF. It will run better and will allow you to squeeze some extra power out of it. The 94-95 have a really shitty stock tune...ongoing argument is the 94-95 computer is garbage, after some debate its not the computer that sucks, its the program. they are really ticky and have to be adjusted perfectly or it will not run as it should....my 95 is no different.
just plan ahead and get as many mods that require a retune done at one time so you dont have to spend tons on retune charges. you will definately see more power out of it with a good tune.
95 GT- AFR 185's, Comp CAM, Trick FLow TH upper and lower, 30lb injec, 76MM C&L kit, Full MSD, BBK Pulleys, 3:73, BBK Long Tubes, X Pipe, Magnaflow Cat back, Cobra front control arms, MM CC plates LCA's and Panhard bar, tuned by Adam @ Pops Racing. |
1995, gt
ok...how hard is it to change the timing? im very inexperienced with cars so talk about timing and WOT mean very little to me. what is WOT? and i doubt i will be able to change the timing myself so how much would it cost to have somebody do that for me? and im considering NOS so should i consider that when i change my timing?
#5 | |
9.74@142
And yes, it is VERY important to take into consideration if you are going to run nitrous. You have to retard timing (from your max efficient timing setting) to run nitrous. How much you have to retard it depends on how big of a shot you plan on running. It would be a good idea to run an ignition box with a timing retard. That way you can keep your full timing when N/A, and it automatically retards your timing when you spray. Check out the Mallory 685 box. It has a 2 step, 12v activated timing retard (perfect for N2o), and a built in RPM window switch (I would not run N2o without one), and a couple more user friendly features that only takes seconds to adjust with a digital readout. I just put one in the LT1. I want to see what it will do with a little shot ![]() IMO it's MUCH more user friendly then the MSD digital6 Mallory Ignition :: Product Details Heres a link to the 685 from summit:Mallory Ignition 685 - Mallory HyFire VI Digital CD Ignitions - Suggested Parts - SummitRacing.com
48.47@ 12.58
Just as a side note.. the 95 was a guinea pig for the obd2 system. Your car may have it.
1995, gt
would the plug in be below the dash like normal or somewhere else...im gonna look for it on my next day off...fiddle around and get more in touch with my car (second girlfriend) lol
48.47@ 12.58
Yea.. it would be below the drivers side dash if your car was indeed obd2.
95 mustang gt
whats the deal with changing 94-95 mustangs to the 89-93 computers. Some peolpe say dont do it because the 95 computer is faster and better then the earlier mustang computer. but i dont see how because i know if u put a cam in a 94-95 u will have tuning problems. i had a 91 mustang i put every up grade u could do to it and never had one problem running stock computer with no tune. i now have a 95 because i like the body stlye better. but every upgrade i do i have ide sruge problems and i know the car isnt running the best it could. i tuned many mustangs and i know everything i can set manurally is right
#10 | |
If you change the cam and the new cam specs deviate far from stock, the stock computer definitely needs reprogramming.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
95 mustang gt/cobra clone
my car has the hook up under the dash but every one on here says its the obd1
#12 | |
9.74@142
The same goes for a Fox 5.0, but less power is to be had with a tune. IMO, Until you go forced induction, or a a H/C/I set up, the gains in a paying for a dyno tune on a 5.0 really are not worth it. Set the timing and the fuel pressure with an AFPR and you should be able to get the car performing vary well.
1995, gt
well i checked under the dash, definitely no obd2 port. im almost certain their are no 95 stangs with obd2. probably just an internet myth that grew once one guy said it on a forum. so how hard is it to adjust the timing and what will that change driving-wise?
#14 | |
My '95 does have the underdash connector but it's about as useful as tits on a bull. Like everyone else I use the connector in the engine bay for scanning codes. |
1995, gt
where would i get an afpr, and is this something i can do myself with basically no knowledge of timing and fuel pressure?
I bought the BBK AFPR from Summit Racing and installed it myself in about 15 minutes. You'll definitely need a fuel pressure gauge to make the adjustments and I went for the Kirban unit that comes with an adapter that screws onto the Schrader valve.
1995, gt
so with my mods is there a "sweet spot" that i should expect? or are all cars different and i will just have to test it myself after each adjustment?
1995, gt
and im guessing it is rather easy to adjust the afpr?
94 Mustang GT
when ever you get it tuned make sure the guy knows what he is doing. cause i have had mine tuned about 5 times and he can seem to get it right. it sucks.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/94-95/148976-95-gt-tune-questions.html
| Page 4 - Last Minute Meet and Dinner Willowbrook mall Tuesday January 10th 7pm - Mustang Club General Meets | This thread | Refback | January 9th, 2012 10:55 AM | |
| How To Set Timing On 95 Mustang - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | January 22nd, 2010 12:14 AM | |
| 95 Mustang Gt Wiring Diagrams - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | January 20th, 2010 06:47 PM | |
Threads Similar to: 95 gt tune questions
| Do you get more gas mileage with stock 87 tune or 93 octane tune? | asiansensation78 | 99-04 | 14 | November 24th, 2009 12:41 AM |
| Tq tune outperforms race tune at the 1/8 mile track. | gragra73 | 2005 - 2010 | 5 | July 28th, 2008 04:16 PM |
| Questions about a cusom tune ? | crod02 | 99-04 | 3 | April 23rd, 2008 11:01 AM |
| Dyno Tune Questions | blakehunter316 | 5.0 Mustangs | 3 | March 11th, 2008 10:55 PM |
| Tune up questions?? | Bill | 5.0 Mustangs | 18 | December 18th, 2005 07:56 PM |
