Builing a 450hp 347
Old January 16th, 2010, 11:19 AM   #1
james christopher is an unknown quantity at this point
Builing a 450hp 347
I have a fuel question what size injectors?
Old January 16th, 2010, 12:22 PM   #2
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
42lbers and a 255 pump will do ya
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old January 16th, 2010, 12:48 PM   #3
Thank you its hard to find detailed info, maybe you can tell t/b size and maf size. I have a 1995 mustang GT,I found a good deal on a 1994 mustang gt with a brand new 347 build most everthing is there. I paid just over a 1,000 for the car with a stroker.
Old January 17th, 2010, 08:31 AM   #4
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Is that N/A or with forced induction?
Is that 450hp at the crank or at the rear wheels?
Realistically I'll assume it's 450hp at the crank (390rwhp) and N/A so the optimum injector size would be 36lb/hr. The 42lb injectors would be appropriate if it was 450rwhp and N/A (tall order on a 347). Either way a tune would be mandatory.
I'd go with a 75mm TB, 80mm MAF, and a 255lph fuel pump.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old January 17th, 2010, 04:08 PM   #5
95opal's Avatar
95 opalfrost gt
agreed in NA form 36rs would be fine. But for one they dont make them anymore and two you should always leave room for growth. Why buy crap twice. makes no sense
WIth the right combimation of parts a 347 can and will lay down those numbers.
5.0 magazines
Old January 18th, 2010, 03:33 AM   #6
Bullitt95's Avatar
13.546 @ 105.32
If that's true then 42lb injectors would be OK, but the computer will need to be reprogrammed with a reduction of the injector duty cycle to prevent the engine from running overly rich.
Old January 27th, 2010, 10:09 PM   #7
Its going to take alot to make the 450 h/p I will have the car tuned after i get done and the breakin period is over. Thank you
Old January 28th, 2010, 09:30 AM   #8
Bullitt95's Avatar
13.546 @ 105.32
450 crank HP = 390rwhp
There are several 347's out there putting down at least 390rwhp so it's within reach. It's just a matter of selecting the right combination of parts.
243.5rwhp/284.2rwtq
Old January 28th, 2010, 10:01 AM   #9
cobramanphil's Avatar
95 Cobra
10.94
cobramanphil is on a distinguished road
Send a message via AIM to cobramanphil Send a message via MSN to cobramanphil Send a message via Yahoo to cobramanphil
I agree that it is always better to have room to go. Before I swapped out motors I always thought that 42lb injectors would be enough. I was soooo wrong. Even without the blower belt attached/running those injectors were barely enough to run n/a on my car up to 4000rpm. So I swapped them out for 60lbs and changed my tune. After a year or so..I stepped up the blower speeds and then guess what...those 60lbs with aftermarket fuel rail/lines/aeromotive fuel pump is running lean again and i then moved to 80lb injectors which gives me more reasonable duty cycles at my shift points (6500rpm). If I were smart about it I would have jumped to 60lb injectors from the start and saved on the bucks buying 42 pounders (easily could have triimmed the 60s in my tune).
The whole point is that one can easily modify the fuel tables/trim/MAF transfer if running big injectors on a combination that probably does not require that large of an injector..it is just in the tune and I see no ill affects about doing it this way.
95 Cobra, vortech, 12psi, big fuel, dart 8.2 decked 363, custom cam, HSM II intake, full MM front and rear..plenty of fun for a street car on street tires and too much spent on parts
Threads Similar to: Builing a 450hp 347
Box builing and tuning how to. Drew S. Audio/Video 33 May 30th, 2009 08:29 AM
Is 450HP too much ? BAzombie 96-98 20 April 21st, 2009 11:39 PM
450hp? acheivable or not? Dolbs4082 99-04 222 March 12th, 2009 08:47 PM
450hp supercharged suburban Kuro The Clubhouse 5 June 11th, 2007 02:13 AM
Is The 5 Speed Auto Trans Able To Take 450hp? Globetrecker 2005 - 2010 16 December 8th, 2006 04:19 PM
