NEW GUY-Needs Help!!!!
Old January 16th, 2010, 03:10 PM   #1
snowwhiteGT's Avatar
snowwhiteGT is on a distinguished road
Angry
I have a 94 GT 5spd. Runs good in the morning after the initial start up. But when i try to start it up again after getting breakfast, i have to keep turning and holding the key for about 10+ seconds before it starts and when it does, it hesitates and runs horribly. Makes me want to kick the tires!!! Only mods are exhaust, MSD coil, MSD dizzy cap and MSD 9mm wires. Any help would be great!!
Old January 17th, 2010, 08:19 AM   #2
Bullitt95's Avatar
1995 Mustang GT auto
13.546 @ 105.32
Bullitt95 will become famous soon enough
Your problem is:
My
Spark
Died
It sounds like a heat soak issue of an ignition component and it's most likely to be the coil.
243.5rwhp/284.2rwtq
Mod list in My Garage
Old January 17th, 2010, 07:13 PM   #3
Is there any coil out there better than stock? I guess i may as well change the plugs too. I'm running Bosch platinum Ir fusion. are these any good? All of this was given to me by the previous owner.
Old January 17th, 2010, 07:24 PM   #4
The Big Spoon
jessemachone's Avatar
88 5.0 5 Speed Notch <><
never fast enough
jessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of lightjessemachone is a glorious beacon of light
also check your fuel pressure... your fuel pump could have issues when it warms up. Don't forget about the ever so popular engine goolant temp switch - it tells the computer how much fuel to start off with. if you hold the pedal to the floor will it start? the reason i ask is that when you hold the pedal to the floor, the computer will use the wide open throttle fuel map and may start. after it kicks, back off the throttle but don't let it go all the way back to idle until it warms up.
Old January 17th, 2010, 07:47 PM   #5
Where is the engine coolant switch? what can i do to check the fuel pressure? I don't hold the gas when i try and start it. I do smell gas thru the exhaust when it finally does start.
Old January 17th, 2010, 09:42 PM   #6
95opal's Avatar
95 opalfrost gt
95opal will become famous soon enough
Get rid of those platinum plugs to begin with 5liters hate them get a set of autolites and be done. Second Have the coil tested to see if its an issue Odds are it isnt. If its only acting up when the car warms up i would look into
Checking the TFI, seems as though your in the early stages of having it go south on ya.
5.0 magazines
94-04 performance mustangs feature car! Fall 2010
Old January 18th, 2010, 04:34 PM   #7
What is the TFI? And how can I test it?
Old January 19th, 2010, 11:20 AM   #8
Bullitt95's Avatar
13.546 @ 105.32
Originally Posted by snowwhiteGT View Post
What is the TFI?
That's the ignition module which sits on the passenger side inner fender below the MAF housing.
Threads Similar to: NEW GUY-Needs Help!!!!
Tough Guy+F18=Not Tough Guy...lol... 1FastFox The Clubhouse 11 January 20th, 2010 05:04 PM
MD new guy DarkStang54 New Members Introductions 9 April 19th, 2009 03:55 PM
theres this one guy zinc02GT The Clubhouse 34 July 20th, 2008 01:19 AM
Another new guy clean huh? New Members Introductions 14 January 22nd, 2008 10:32 AM
Just another new guy NotA35R New Members Introductions 2 July 23rd, 2007 10:45 PM
