Need Help!!!
Old January 16th, 2010, 05:10 PM   #1
eternity8969 is on a distinguished road
Need Help!!!
I have a 95 gt that seems to start when it feels like it. Sometimes the engine cranks but it won't kick over. Other times it'll start and i'll drive it for a few min only to find that it dies in the middle of the road and won't start again. i replaced my coil because i was getting a weak spark from the old one. I also replaced my pip sensor in my dist and put in a new Ignition control module. When i run my diagnostic i came up with a code 556 which is "fuel pump relay fault." Is the problem in my relay or should i be looking in another direction?
Old January 17th, 2010, 02:02 AM   #2
BoostFiend's Avatar
'03 Cobra, '89 +'91 Notch
11.63@120.08, Cobra
BoostFiend is on a distinguished road
Do you get the fuel pump whine when you turn the key on? I would say check all your grounds as well. My money is on fuel pump or faulty ground.
Old January 17th, 2010, 02:52 AM   #3
I do get the whine from my fuel pump. Also sometimes when i turn the key into the on position but not cranking the engine my fuel pump will cycle 3-10 times and my check engine light will flash coinciding with it. It doesn't throw a diagnostic code though unless that would be the fuel pump relay one.
