Tall Valve Covers Needed???
Have a question for you guys .. I'm putting on a set of GT40 P heads and a set of pedestal mount 1.7 roller rockers on my 95 GT and was needing to know if I need to install taller valve covers with this setup?? Also will the taller valve covers be an issue if used ?? Thanx in advance..
Tom Last edited by lakefrontlivin; January 24th, 2010 at 09:44 AM. |
The stock valve covers should work fine.
![]() 243.5rwhp/284.2rwtq Mod list in My Garage |
Thanx for the reply
![]() Maybe I'll look for some nicer looking ones.. Thanx, Tom |
1990 gt 2006 gt
.99@14mph
If it is anything like my 87 5.0 that i put a set of Edlebrock heads on with 1.7 RR you factory valve cover wont clear it. I had to by a taller valve cover and a intake spacer.
1994 GT
11.75@120
I just built my 347 stroker and if using roller rockers you will definitely need taller valve covers to clear them. Problem with the sn95 body style is that with bigger valve covers you then have clearance issues with your intake and anything atttached ie:throttle body. Then you will have to worry about your intake not clearing your stock upper strut tower brace and possibly even your hood
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers ...E/T: 11.75 @ 120mph 2.0 60foot |
1991 Mustang LX 5.0
I used to run factory valve cover's on my motor with roller rockers. Just had to remove the oil splash baffle thing. Your motor with Ford heads, no different. Can't speak for aftermarket heads.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
#9 | |
Yes.
With taller valve covers, you could run into another issue and that is whether the intake elbow will clear the passenger side cover. If not, you'll need an upper-to-lower intake spacer and then you could run into yet another issue and that's hood clearance from the upper intake. It could go on and on.
These are pedestal mount roller rockers.. Hope they clear
![]() Thanx, Tom |
1997 SVT COBRA
1996 Mustang V6
![]() ![]() ![]() ![]() ![]() ![]() iTrader: 14 reviews
I ran 1.7s with aftermarket covers but they were damn near stock height so you should be fine.
![]() -04 IRS - Magnaflow - Wheel Replica - Autometer - FTBR - FRPP - SCT - Brembo - PRO 5.0 - BOI- |
2002 mustang gt
![]() iTrader: 1 reviews
should be fine, not to sure
98 GT 4.6
be sure to remove the oil fill baffle. if your interested. i have a set of polished valve covers witht he baffles removed ..ready to use.
#14 | |
This is getting frustrating !!! ![]() Tom |
I run the trick flow standard height, tfs heads, 1.6 stud mount, aluminum rollers, sn95,585 lift, alternator clears fine- 109.00 shipped at summit racing
Threads Similar to: Tall Valve Covers Needed???
| NEEDED ASAP: romeo valve covers | 2000stangGT | 99-04 | 0 | July 24th, 2008 10:34 PM |
| valve covers | 91cobra5.0 | 5.0 Mustangs | 1 | May 31st, 2008 03:33 PM |
| Valve covers | jrfan4life | 99-04 | 13 | January 1st, 2008 06:31 PM |
| Need advice on tall valve covers | Zak | 94-95 | 0 | August 3rd, 2007 02:20 PM |
