Tremec 3550 in my sn95
Old January 28th, 2010, 11:09 PM   #1
smott's Avatar
1994 GT
11.75@120
smott is on a distinguished road
hey just picked up a tremec 3550 from a buddy running it in a fox body. I wanna it in my 94 and i was wondering what needs to be done to make it work ie: bellhousing, crossmember, driveshaft?????
Ford Racing R block stroked 347. Trickflow stage 1 cam, Trickflow street burner upper and lower, gt40P heads, BBk 75mmTB, 03 cobra MAF, Zex dry kit, Tuned by PSI Motorsports, stock valve covers...
E/T: 11.75 @ 120mph 2.0 60foot
Old January 29th, 2010, 12:50 PM   #2
95stroker's Avatar
1995 Mustang GT
95stroker is on a distinguished road
Been a while since I had mine put in, but if I remember right you use the stock crossmember. I believe you need a new bellhousing and will need a small spacer that goes on the rear of the driveshaft - I can climb under the car and post a picture if that will help at all. Details aren't 100% positive because to tell you the truth, I wussed out and had a shop install it because I wanted a warranty on the installation. I have a TKO in mine, but I believe all should be the same. You will also want a new shifter if he isn't giving you one with it.
Threads Similar to: Tremec 3550 in my sn95
Opinions on a Tremec 3550 nolife 5.0 Mustangs 13 March 19th, 2009 07:18 PM
Tremec 3550 anyone? Stangzilla 5.0 Mustangs 6 March 13th, 2009 10:48 PM
Tremec 3550 Tony_90fox The Clubhouse 5 August 26th, 2007 12:11 AM
tremec 3550 rebuilt Levon 5.0 Mustangs 1 August 13th, 2007 03:09 AM
Tremec 3550 sn-95aac 5.0 Mustangs 12 August 12th, 2007 04:24 AM
